Question about Dewalt DW071KI Laser Levels and Rotary Lasers
How to calibrate DW071 rotary laser.I set laser level with vials but the red laser light is not shooting consistently level
2 Suggested Answers
SOURCE: I need to calibrate rotary laser DW073
Sounds like you figured this out on your own. I calibrate my own DW073 regularly without any fancy gadgets. I use the calibration check procedure in which the unit is placed about midway between fixed objects 100' apart.
These have a front and back and sides, so first you mark where the laser hits facing front to back at your targets. Then turn it 180 deg. relevel and resite. If the difference between the new and old marks is not the same then I turn the adjuster to halve the inconsistency and once that is accomplished, tweek the adjusting screw at the end of the level vial. (Because if you have adjusted more than the tiniest bit, the bubble will no longer display as level. So having established level, or closer to it, the adjustment here is actually to bring the relevant bubble vial back to level rather than assume they are level and adjust the physical beam mechanism (unlike the old physical sight levels where you adjusted the actual optics -- a little more like adjusting a rifle scope). Then you repeat for the side to side vial.
Anyway sounds like you are set so I posted this for anyone who happens to find this thread and is looking to field calibrate their DW073, e.g. don't have time or money to get it done in some shop.
I also wanted to post an add on question. Did you figure out how to adjust the "cone error", i.e. the accuracy of alignment of the twin lasers. They appear to have allen set screws that lock their adjustment, and maybe they are then reaimed by using a slotted screwdriver on the brass ring surrounding the laser. Maybe these are made eccentrically or slightly beveled so turning the laser reaims.
So far, my cone has stayed within the specs of 3/32" at 25' in the manual. But I'm seeing two lines at maybe 150' out. Probably that is close enough for gvmt. work, and I may find the adjusment so sensitive that I can't really get it any closer. But I'd at least be interested to know the method for adjusting the cone error.
Thanks,
Brian
Posted on May 06, 2010
How do I check if my dewalt spinning laser is accurate?
Set it up and shoot 4 level points around the laser . Like at 12 -3-6and 9 o clock. Move the laser 15 or 20 ft from where it is now and re-shoot those 4 points again .if they don't read level then your laser needs calibrated
Jan 07, 2015 | Dewalt Self-Leveling Line Laser...
Geo fennel fl200a-n calibration
ck to see that piviot bearing does not have and dust or junk in it and moves very easy , i use mine for drywall and i have to clean out piviot all the time to get proper level from it
Jul 06, 2014 | Stanley 77 156 RL100 Manual Leveling Dual...
The off level light doesn't turn off therefore doesn't level at all,
Your vial and compensator no longer match up. Move the foot screws until you can get your laser to spin, then adjust your leveling vial until it reads level again, using the 3 screws holding the vial inplace.
Aug 18, 2013 | Spectra Precision Laser LL500 Exterior...
Laser is level but out of level light blinks and will not spin
Your compensator and leveling vial are no longer aligned. Use your foot screws to find a place where the laser spins, then use the 3 hex head screws on the vial, to adjust it to read level.
Dec 23, 2012 | Spectra Precision Laser LL500 Exterior...
Topcon rl-60b
Hopefully it's the simple answer. The bubble vial may be out. start where the level vial says is level, and move outwards in slow circles to try and find a place the laser thinks is level. if you find a spot, use the 3 adjustment screws on the bottom of the bubble vial to make that your new center.
Otherwise, it's a not good news. A couple things could be gone wrong. The oil bath compensator could have leaked. If you open the laser, and it's oily inside, throw it away.
It could be the peep site could need adjusting, or the laser diode could be blown. If the laser diode is dead, same solution as the compensator leaking. There are no parts available for these anymore, chuck it out.
The peep site isn't a write off, per se. The laser operates by shooting the beam through a oil bath, which compensates for the instrument not being perfectly level, and then through a splitting lens. part of the beam travels up, and through the rotating head. And the rest goes through a peep site, to a light reflecting area of the main circuit board. if the board or peep site is no longer aligned, the laser will never think it's level. The bad news about that, it is a very tricky and time consuming repair, that few technicians know how to do, or if they do know how are most aren't comfortable doing it.
You can try taking the cover off, leveling the instrument, powering it up and trying to move the circuit board until the laser thinks it's level, but i wouldn't waste much time on it.
Aug 27, 2012 | Topcon Rl-60b Rotating Laser Level C/w...
My dw071 spins but will not light up
The laser diode can be dead or one of the very thin wires on the laserdiodeunit can be broken
Because of the callibration of the laser and more small underlying defects in assembly and disassembly of the laser block and the x and y axis control is to abandon self-repair.
May 16, 2012 | Dewalt DW071KI Laser Levels and Rotary...
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
Cant calibrate laser
You must place the unit 30' from a wall, level the unit with the level indicating vials, mark spot on wall or object, rotate laser 180 degrees and level with vials again, if it comes to the same spot your unit is calibarated. if not then you must do this process at least 2 times(1 for each directional level) and use the adjusting screw to move vial. it takes a while to get it right.
May 04, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
Thanks,
Brian
Feb 15, 2009 | Dewalt DW077KD T Self Leveling Rotary...
Dewalt DW071KI Laser Levels and Rotary Lasers Logo
208 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
