When I uae turn signals on my 2003 camry the hazard lights flash. could it be a relay switch?
  • jnemchev Mar 26, 2011
    can you supply me with detailed instructions on replacing the relay switch. diagrams and location would be helpful.
  • 3,530 Answers
Welcome to Fixya
Yeah you are correct. There are no other possible cause of this problem other than a bad relay switch. Replace the relay switch and you are good to go.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Mar 26, 2011
  • Jose Cada
    Jose Cada Mar 26, 2011
    The flasher/relay unit (electronic 3-plug) is rectangular and plugs into a patch panel under the driver side console. It's near the left foot rest and you should be able to see it and reach it. Look lower and to the left, which is just about where your left foot would normally rest, and it'll be in the area to the left of your left foot.
Hazard lights work but not turn signals
hi. see if it as a relay in the circuit. most car lighting these day have
relays. mines got loads. good luck
Feb 23, 2014 | 1989 Toyota Camry
Rear lights not working on 2002 suzuki grand vitara
In the underdash fuse/relay box, the 15A TAIL fuse feeds power to the coil of headlight relay 2. When the combination switch is set to TAIL, the relay closes and the outer tail lamps light. In the same underdash fuse/relay box, the 20A STOP fuse feeds power to the brake light switch. When the brake pedal is pressed, the inner brake lamps light. The underdash fuse/relay box also contains the 10A TURN BACK fuse which feeds power to the hazard switch and the turn signal relay. Relay output is fed to the combination switch and turn signal power is applied to the selected middle tail light. The fourth fuse in the underdash fuse/relay box is the 15A HAZARD fuse which feeds power to the hazard switch and turn signal relay. When the hazard switch is set, the turn lamps on both sides begin flashing.
Sep 18, 2012 | 2002 Suzuki Grand Vitara
After using turn signal you can still hear clinking, is hazard relay part of turn signal
The hazard switch is also the device that supplies the turn signal "flash". If you continue to hear the noise of the turn signal flashing when the turn signals off than the problem is the turn signal switch. It is grounding The purple wire from the hazard switch which makes the hazard switch think the turn signal is on. The fix for this is to relace the turn signal/multi-function switch. Typically they will start to go bad in stages. Your symptom is the first stage. Eventually either the turn signals or the brake lights will also sto working. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 10, 2012 | 2000 Oldsmobile Alero
Is the hazards relay used part of turn signal?
92 caprice classic turn signals not working, but the bulbs are fine. Hazards, brakes, etc all work fine. Any ideas?
Yes, the problem is the turn signal flasher is defective. You can has two flasher relays. One for the turn signals and one for the hazard lights. That is why the hazard lights flash and the turn signals do not. Replace the turn signal flasher relay located on the drivers side of the steering column, mounted behind the instrument cluster in the convenience center. They are both mounted in the same location so turn on the hazard lights and the one that you put your finger on that is not clicking is the turn signal relay.
Mar 08, 2011 | 1992 Chevrolet Caprice
How do I change the turn signal relay
the turn signal relay is part of the hazard light switch assy. you will need to replace the intire hazard switch assy. check with your pontiac dealer some of these switches were recalled......GOOD LUCK
Dec 13, 2010 | 2003 Pontiac Grand Am
Where is the turn signal relay, hazard relay, and flasher for a 2003 Ford F150? My turn signals do not work (inside or outside), but 3 out of 4 outside lights work when the hazards are on, but with only 1...
It is not the flasher if the hazards work, it is 1 flasher for both turn signals and the hazard lamps. It is in a relay block ( along with the blower motor relay ) under the dash, about in line with the steering wheel column ).
Try tilting the steering wheel all the way up, and test again.
The other quick test is to cycle the hazard switch a few times, to see if it cleans the contacts for the turn signal on the MFS,
Apr 01, 2010 | 2003 Ford F150 Regular Cab
1999 Camry Turn signals and hazard lights not working.
located on the firewall panel on the left side of the floorboard on the drivers side
Feb 02, 2010 | 1999 Toyota Camry
Turn signals wont work fuses are good?
the hazard switch above the radio is your problem. if you put on your signals and they don't flash turn hazards on then off and they will flash. (changing this *** will fix your problem
Aug 30, 2009 | 1999 Pontiac Grand Am GT
Hazard Lights working. Indicators will not operate/flash
The Hazard and turn signals share the same relay module located in the dashboard behind the hazard switch. Remove the trim by prying from the sides (Either side of the Cup holder drawer and Card drawer). Pry the hazard switch assembly out from the dashboard. The relay is part of the hazard switch assembly.
Unclip the wiring terminal from the relay. replace with appropriate relay. Part costs under $50.00 delivered from Import Parts Specialists.
Nov 02, 2008 | 2003 Audi A6
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
