Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Print error 50
Paper jam
  • krkasha Aug 06, 2008
    Paper Jam on top paper error. When Printer starts it starts to initialize and fails with INIT 50 error. Paper jam was removed through the top area in the back when the cover is open
THIS DID NOT FIX OUT PROBLEM.
Posted on Sep 23, 2008
Is there a door at the back? My 640 has one and you must open it to clear the jam.
Posted on Aug 07, 2008
4 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc845cw
See picture how to do that :-)
Posted on Oct 02, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
the kowalski
  • 86 Answers
SOURCE: message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Posted on Jun 02, 2009
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Hp laserjet 4200 will print a 50 page paper path test, print an extra page and then jam.
The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
Oct 03, 2012 | HP LaserJet 4200 Printer
Unable to print 50
Error 50: The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam.
See here for illustrated instructions on how to clear a paper jam.
If the problem still continues after clearing the paper jam it could mean a problem with a sensor and you may need to contact a service representative.
For future reference a list and explanation of Error Codes can be found here.
Trust this is helpful.
Jan 04, 2011 | Brother MultiFunction Center MFC-440CN...
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
Message unable to print 50
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
Jan 23, 2009 | Brother MFC-3240C All-In-One InkJet...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Nov 05, 2007 | Brother IntelliFax-2480C Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
