Question about Dell E156FP 15" LCD Monitor
I have a E156FP LCD Monitor. When I turn on my computer, it will show the initial Dell Screen and then the screen goes black. The green power light turns orange. If I push either of the (+) or (-) signs, the power light turns green again and a message pops up saying it is in power save mode and to press any key or move my mouse to bring it out of power save mode. Then the screen goes black again and the power light turns orange again. However, when I press keys on the keyboard or move my mouse it doesn't do anything, the screen stays black. I know there isn't a problem with my computer tower as it works fine with a friends monitor hooked up.
    Top Expert:
  • Dell Master
  • 79,024 Answers
The monitor has failed, it is almost always cheaper to replace it than fix it.
Posted on Apr 05, 2017
  • 749 Answers
SOURCE: Monitor not receiving data from computer?
If you did not hear any beep from your CPU, then the problem is in the system not the screen.
Try connecting the screen to another computer and try also a working screen of a friend to your computer...
You'll find out that either the screen or the computer...
Good luck... post me back for your result.
Don't forget to rate too.
Thanks...
Posted on Jan 29, 2008
SOURCE: Dell E173FP stuck in power save mode
What if both the monitor and computer are stuck in power saver? There is no way to get to the control panel. Then what?
Posted on May 14, 2008
  • 461 Answers
SOURCE: In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Posted on Nov 17, 2008
  • 4090 Answers
SOURCE: Problem w/Dell E176FPf monitor stuck in power save mode
Ok if it the monitor works fine on another unit discount it out of the equation as a monitor problem.
I would suspect the driver on the PC that delivers the problem, especially the video card.
. Check that the cable is also on tightly. remove it and even clean the pins and replug it .the plug on that PC may be dirty
You May need to replace the video card as the communication to the monitor is intermittent and that is why you get the amber light.
Open the box with power off. clean the card if it has a lot of dust on it ( most do and its always a shock) wipe it over ( BOTH SIDES) and then try to start it up as usual with the monitor connected to see if that fixed it ( sometimes works) if not get another card and replace it. Best I can offer without being there to help on the spot.
A new card should allow you access to install and configure it and these days they are pretty cheap to buy
Please rate this help to keep the service online
Posted on Aug 20, 2009
  • 23 Answers
SOURCE: monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Posted on Apr 19, 2010
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Dell E156FP Monitor Problem
If the screen is not completely black (i.e. just very very dim, turn the lights off to see) try using the controls at the bottom of the monitor to reset to factory settings (all settings). I have had this problem with two dell monitors so far and this seems to work.
Jan 08, 2009 | Dell E156FP 15" LCD Monitor
Dell 15 inch lcd monitor issue
The first thing you should do is change the monitor for another known working monitor to make sure it is the monitor that is faulty and not the video output of your computer.
Aug 03, 2008 | Dell E156FP 15" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Green Screen
There are seveal cause to this issue, but with out seeing what your seeing I recommend that you search youtube on this one.
https://www.youtube.com/watch?v=84HPv6Epknc
Mar 05, 2017 | Dell E156FP 15" LCD Monitor
Dell E156FP 15" LCD Monitor Logo
67 people viewed this question
Alun Cox
