Question about Frigidaire Over-the-Range Microwave
My microwave exhaust fan is not working right im getting good air out the went but no suction at the bottom , please help
3 Suggested Answers
  • 574 Answers
SOURCE: Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Posted on Aug 31, 2009
  • 43 Answers
SOURCE: microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Posted on Feb 03, 2008
Kenmore model 721 - Cooked a meal for 30 minutes. Afterwards the microwave did not heat. However, the next day it worked. A few days later, was operated for 20 minutes, and again did not heat, and has not...
Yes, there is a thermostat device located on the magnetron. It will open up (turning off the magnetron) when it gets too hot, and it will reset automatically after it cools back down (in 5 to 15 minutes). The question is, Why is is over-heating? Usually it is caused by the exhaust fan being turned the wrong way. (For example, it may be set to exhaust the air out through the top of the microwave, but you don't have a vent there.) That fan can be turned to exhaust air out the top, out the back, or recirculate the air back through the front of microwave. It's easy to turn it around - the hard part is that you have to take the microwave down to be able to pull the fan out and rotate it the right direction.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 17, 2015 | Kenmore Microwave Ovens
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 24, 2013 | Frigidaire Microwave Ovens
Frigidaire gallery otr microwave vent not working
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
Apr 04, 2013 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Microwave exhaust fan doesn't really exhause any steam out. Model 721.80042700
The fan is for cooling the magnetron, nothing else. Steam remains in the cavity which is why the door should be left open after cooking to allow the steam to evaporate.
May 30, 2017 | Kenmore 30" Microwave Combination...
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Exaust fan has weak suction on maytage mmv4205baw
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Maytag MMV4205 Microwave Oven
Microwave oven exhaust fan
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Frigidaire Over-the-Range Microwave Logo
145 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
