Question about Jenn-Air Grilling
I have a Jenn-Air model #720-0138-NG built in and one of the knobs won't turn far enough to light/ignite the burner.
SOURCE: jenn-air grill
Cleaning burners"
Posted on Jun 09, 2008
SOURCE: Jenn-Air outdoor grill - model: 720-0150-LP
your propane hose or tank has a leak and the regulator is restricting flow
Posted on Aug 22, 2008
ginko
  • 19396 Answers
SOURCE: jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Posted on Sep 16, 2008
  • 11 Answers
SOURCE: The gas flow is very low to the 3 burners on my grill
Hi - assuming there is no severe kink in your gas hose and there isn't any other obstruction in your gas line, a likely cause is that your regulator is faulty and may need to be replaced. I don't think they are very expensive.
You may want to post your problem on the Jenn-Air section of this forum: http://www.bbqsource-forums.com
I've had good luck getting help there with my grills.
Pat
Posted on Nov 28, 2008
SOURCE: 1st burner goes out when 2nd burner is turned on
I had the same problem. They original regulator and hose were poorly designed for this model. There isn't enough room underneath without crimping the hose. I bought a standard regulator and shorter hose combination a Home Depot for about $20. It makes a 90 degree turn coming out of the tank and does not kink the hose.
It was worth the $20.
Posted on Jun 03, 2009
Jenn-Air Dual Fuel Range Model JDT8895BAS
The igniter will click on all the burners simultaneously no matter which burner knob is on. This is normal.
Aug 27, 2014 | Cooktops
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
What are the btu ratings for a jenn air model 720-0100 ng grill. i am converting this to lp gas...
does not matter just change out the orfices on all burners and back burner even if you have a IR buners, the orfices let enough gas in for your grill call jenn air they will sell you the kit to convert it over
Jul 29, 2009 | Jenn-Air Grilling
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
Dec 01, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Grilling Logo
74 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
