Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Hotpoint refridgerator yes it whined for about a year now it isn;t keeping cold for the fridge or freezer any ideas? it is actually a hotpoint hss22ifmb ww
  • 1 more comment
  • tony597 Aug 29, 2008
    I have the same problem just developed overnight. Did the fill of Freon work? Can we get this over the counter?
  • ruffster05 Nov 28, 2008
    I have a Hot Point side by side refrigerator and the refrigerator is not getting cool. The model number is HSS22IFMB WW
  • Anonymous Dec 29, 2008
    DO not fill with freon,, first remove inner back panel of freezer unit.
    If the coils are frozen over, you will need to unplug and manually de-frost with either time, or help from a fan.
    DO NOT attempt to physically remove ice from the unit.
    Check the rear compressor coil for dirt and dust and clean.
    Empty the ice-maker.
    When this is all done, replace the panels and parts.
    Set both cold controls to 5.
    Plug in, and wait for unit to stabilize. If it gets gets cold, the problem is in the defrost circuit, NOT freon or the compressor.
  • 3 Answers
Fill with freeon
Posted on Aug 04, 2008
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
I have a ge side by side fridge model number GSH22JFXL ww and the freezer is working great but the fridge is not cold at all.
If the freezer is working great and you don't have frost build up on your coils (this would be a defrost problem) and your fan is running in the freezer, then first check your control settings.
put both your freezer and refrigerator controls in the middle position. your refrigerator gets its cold air from the freezer. the freezer control is actually the thermostat control. this controls the compressor. the refrigerator control is basically an air damper that allows more or less air in from the freezer.
by placing both controls on 9, you may think that you are turning both controls wide open when you are actually making the compressor run longer yet the air damper is keeping that cold air mostly in the freezer.
allow 24 hours for stabilization
Jul 02, 2010 | Refrigerators
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Jul 20, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator Not Getting Cold--HotPoint HSS22IFMD WW
Take a look to the thermostat first!
Jun 24, 2009 | Refrigerators
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Refrigerator not cooling
Check in the freezer section by removing the food exposing the rear inside panel. DO you see frost beginning to build upon the rear inside panel of your freezer section? If so, the is a simple defrost problem and can be repaired easily. For testing purpose, st both control to the middle setting and do not move them during the entire testing period. Moving the controls only makes things worse.... Let me know what you find....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge side not cold-freezer great
there is a three prong replay that hooks up to your compressor sounds like it needs to be replaced
Sep 01, 2008 | Refrigerators
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
245 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
