Question about Sony Playstation 3 (PS3) Console
It seems that the "motor"
    Novelist:
    Sniper:
  • 51 Answers
Hi david,
The disc reading problem is quite a common one!
It is caused by the laser coming away from the drive and you need to readjust the laser to get it to work.
Sounds bad but at least the drive is not broken JUST the laser needs readjusting.
Now let us look at how you can fix this:
Solution 1:
The normal way to fix this is to send it in and they will do the work for you at the factory. However it will cost about $150 and also you will have to wait about 4 weeks.
If you do not play on your PS3 that much this may be the best solution for you.
Solution 2: For A Faster Fix
If you want the games reading problem fixed quickly then you should check out some good PS3 Repair guides.
They normally include videos showing you how to readjust the laser - it takes about 20 mins.
Make sure you check out the full reviews below so you can fix a good one!
Click Here For A Full Review Of The Best PS3 Disc Reading Fix
Hope this helps and if so please leave a comment or if you have any questions let me know?
Posted on Mar 29, 2011
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
I have a dvd player built into my tv and until a few weeks ago worked fine. Now when I put a dvd in it tries reading it, i can hear it spin, then after a few minutes stops and says "incorrect...
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 11, 2011 | Sharp Televison & Video
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Will not accept dvd
you've got a bad player. the motor inside that plls in the disk and spits it back out is toast. replace the dvd player
Feb 16, 2010 | Nesa Vision NESA NSCM-1040 Overhead Flip...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
