Question about Dell 3300MP Multimedia Projector
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?, but doesn't do it in cool down mode. Thank you.
  • 442 Answers
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Posted on Mar 26, 2011
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I have a dell 3300MP projector. When starting up the Dell logo is displayed fine. After about 1 minute the unit goes to a solid amber temp light status. Projector display turns off. Unit shows...
Make sure the cooling fan is working and air is reaching the light source, you can hear it running (low whirling noise) when you turn it on, if not that is the problem.
Mar 17, 2017 | Dell 3300MP Multimedia Projector
Plugged up came on about 20 minutes later shut down and went to a yellow blinking mode monitor stays yellow i unplug monitor from cpu and works good do you have any suggestions
Could be getting too hot. Make sure all fans, cooling fins, heat sinks, HDD vents and weep holes are unobstructed and clean. Many computers have a BIOS screen at startup that will display system temp. Start it up and enter the BIOS, check CPU temp. Most PC's will shutdowm or reboot if temp exceeds 140 (this can be adjusted).
If not overheating, could be fault in a memory module, HDD failure, or CPU itself. But that's not that common in the scenario you're talkin about
Dec 11, 2009 | Dell OptiPlex GX260 PC Desktop
I have a dell 3300mp projector hooked up to a dvd player and I cannot get any sound. What do I do?
sound form your projector? or from your speakers? set the volume of your projector to maximum. then check your connection cables if good your speakers if working. check all your component have pwoer supply.
Oct 28, 2009 | Dell 3300MP Multimedia Projector
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Dell 3300MP Projector
my advise is to get a new one or try ebay - i got my dell 3300mp NEW in box for under $400 - and have looked at other projectors there are very good deals on ebay but make sure you read the entire listing
Sep 13, 2007 | Dell 3300MP Multimedia Projector
Dell 3300MP Multimedia Projector Logo
352 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
