Question about Dryers
I replaced the heating element and the thermal fuse and still no heat. how do I check the thermostat? where is it? thanks, mike
  • Dryers Master
  • 528 Answers
Hy mike what is your model # and what brand ?
Posted on Mar 27, 2011
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
Hi.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Regards.
Ginko
Aug 09, 2011 | Amana NED7200TW Electric Dryer
Should you have continuity on the cut off switch?
4239059.jpgcheck this out: If either one of these limits mounted aside the heat chamber check open the dryer will not heat but it will run. These come in a kit with both limits and both limits need replacement.
Apr 11, 2010 | Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
My dryer will run, but will not heat.
Hello there
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
Wont heat up
Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
Jan 22, 2010 | Dryers
There is no heat to dry clothes.what do I do?
My dryer will not heat up.Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 12, 2010 | Kenmore Dryers
Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
Hello there
Here is a list of item for you to check Hope this is very helpful for you
Best regards Richard
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
No heat,tumbles,but no heat. good cont. thru thermal fuse,no cont. thru thermostat internal bias? think that is my problem? Any thing else I should check? I get good cont. thru heat coil also. thanks mike
If the dryer runs, but does not heat, you need to check the Thermal Cut-out and Hi-limit thermostat. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The TCO and Hi-Limit Thermostat are mounted on the heater box near the heating element. Read through the info I provided and double check the continuity of these components. If either the TCO, or Hi-Limit thermostat are bad, replace them BOTH at the same time. Failure to do so may result in premature failure of any replaced components. They are commonly sold as a set.
NOTE: The Thermal Fuse and Internal Bias Thermostat are located on the air blower housing. If the Thermal Fuse were bad, the dryer would not run at all. The Internal Bias thermostat may still cause heating problems, but is less likely. Replace it if you like, but I think you may have a TCO that has failed.
If there has been a failure of the heating circuits, I would recommend you do a thorough cleaning of the dryer exhaust ventilation ducting to ensure you have no clogs. Poor air flow is the number one cause of dryer failures.
If you have questions, please let me know. I hope this helps you.
May 05, 2009 | Kenmore Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
