Question about HP 12A Toner (Q2612A) Printer
My toner is printing few lines darker and few lines lighter
  • 391 Answers
Remove ink catridge and wipe with dry cloth ,replace catridge and print test sheet if its still doing the same ,ajust the paper intake this shoulf solve the problem goodluck
Posted on Mar 26, 2011
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
The right side of the printable portion of each doc prints light
You just need to remove the toner and reach in with a dry rag and wipe the little inch wide window that is above where the toner goes. This window gets covered with toner dust and makes prints lighter...It runs all the way from right to left above the toner and drum.
Nov 03, 2009 | HP LaserJet 4100tn Printer
Samsung SCX-4521F / Fuzzy thin lines when printing from PC.
If your toner cartridge is very old please replace it or it new clean scanner unite all mirror with glass cleaner or cystal cleaner.may be fix your problem.
May 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Gestetner 3245 get lighter wen run 50 to 100 pgs
the amchine runs a density patch every 50-75 prints if you run long jobs it cannot run patch till job is finished which is why your copies get lighter the longer the job
Jan 14, 2009 | Office Equipment & Supplies
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
HP 12A Toner (Q2612A) Printer Logo
203 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
