Question about SanDisk Sansa e250 MP3 Player
MP3 i tried to unclickthe "create folder heirarchy device but i cant ,its not an option... what do i do?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
6ya staff
SOURCE:
To use innovatek mp3
It does not appear they have any downloads at their sites yet.
Did you look through the file heirarchy to find the folder marked "music"? It might be as simple as that. Don't be afraid to look through the folders in the unit.
However it may be one that requires the music be loaded onto the unit via Windows Media Player.
You might query them if there are no other folders to load the music and loading through Windows media player leaves you with no playable music. http://www.innovatek.us/.
Dec 18, 2011 | Audio Players & Recorders
How do i transfer files from sansa 260 to commputer
Connect Sansa to computer
Double-click "My Computer" icon
Double-click Sansa icon (shows up as "Removable Drive" on some computers)
Select Tools --> Folder Options --> View --> check "Show Hidden Files and Folders"
Double-click Music folder
You should see your music files
Right-click your desktop and create a New Folder - name it some useful name
Drag a music file from the Sansam usic folder to this new folder you have created no your desktop --> it should copy the file to this new folder you have created
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e260 MP3 Player
Making playlists on my sony walkman mp3 player
OK so it is a little confusing on how to create a playlist, I am about to make your headaches go away on this issue.
1.Plug your mp3 player into your computer. 2.Go to my computer and open your mp3 player in windows. 3.go to your folder on your mp3 player that you have files folders etc.. that you would like to add to a playlist. 4.right click on folder and choose "create playlist" 5.Name your playlist.
thats it ! you should now have a playlist on your MP3 player, I hope this helps.
Jan 07, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Cant transfer limewire music from my computer to my mp3
Greetings!
Once you insert the mp3 player, the computer automatically detect the device, were you can see the folder inside of your mp3, create a folder from file, new, folder.
Now open the folder where the music was downloaded usually you can see that file at my document, save/complited folder, select all the file, copy
Open the new folder (which you created) in the mp3 then paste the songs that was downloaded.
To play the music in the mp3 player, just find the folder you created.
Thanks
Nov 09, 2008 | RCA TH1101 MP3 Player
Samsung Yp-T10 mp3
hi!~ I need you help.
I connected my mp3 to computer,
and opened the mp3 folder on computer,
and i'm supposed to see the system folder right?
but I couldn't find one for mine.
how do you create system folder on Samsung yp-t10?
that my problem too....
Aug 23, 2008 | Samsung YP-T10 Digital Media Player
Loading mp3 files to garmin nuvi 350
The device is not recognizing the file name. The Garmin GPS will only recognize MP3 files. Ipod (MP4) and other media files will not play. Converting the files to the MP3 format will correct the problem.
Jul 25, 2008 | Garmin Nuvi 350 Car GPS Receiver
Adding Music To My Sansa e250
I never use Windows Media to add music to my sansa... If you want all music to show up click on my computer and then click on the icon for your sansa. there may be a folder that says music but if not it is a hidden folder. if this is so you must go to tools, then folder options, and then the tab that says view. under this will be an option that says hidden files and folders and click show hiden fles and folders and OK. this should allow you to see the music folder. from here on you can just copy and paste all files.
Feb 10, 2008 | SanDisk Sansa E280 MP3 Player
Troubleshooting
Hoot the MP3 player to your computer. Open My Computer and open the external hard drive device that is now listed (this is your MP3 player). After your have opened your MP3 player you should see whatever folders currently exist on the player. Right click and you will see the option "new" or "new folder" to create a new folder. When you select to create a new folder you can click on the name and rename it whatever you want. Hope this helps!
Dec 29, 2007 | iLO (2 GB) MP3 Player
Putting music on mp3 player
after hooking up the device to your USB, open my computer and you should see something like removable drive E or some thing like that. Double click on that device and drop your songs in there and give a try. Some of these devices do not come with a default music folder created already. You have the option of creating one if you wish just like on your hard drive. Or just drop them into the device it's self.
Jun 30, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
