Question about Logitech Cordless Mouse
I sometimes can't drag letters. Do these logetch's wear out?
  • 112 Answers
Any mouse will have it's life. Chances are the buttons on the inside of the mouse soldered to the main board are going bad. Replacing them requires disassembling the mouse and some solder work. It isn't really worth the time, since you can get wireless mice for $20 or less nowadays.
Posted on Mar 26, 2011
How to download a file from word on a Lenovo a10_30 tablet to flashdrive?
It's an sd card! You could use a card reader connect it to your pc then insert the sd card you could then plug the FD and copy the file!
Jul 28, 2017 | Lenovo Tablets & eReaders
Sony Vaio keyboard repeating letters
Keyboards to wear out, but are not expensive to replace. Multiple key strikes and sticking can be caused by spilling "stuff" into the keyboard, even crumbs will do it.
Oct 29, 2015 | Sony VAIO Computers & Internet
How can I set the drag on a shimano R 2000 spinning reel
The letter "R" on a Shimano reel typically indicates it has a rear drag.
you should find a know on the bottom end of your reel that allows you to adjust drag tension. Just Remember to back off or loosen your drag when not using your reel to keep your drag in proper working condition.
Dec 06, 2014 | Fishing
I hear a dragging noise under the drivers seat in my 2003 330xi bmw
Have any of them actually pulled the wheels to inspect the brakes? Pad lining may be low enough to make such a sound/feel especially if it just started making contact with inner pad wear sensor.
Jan 14, 2014 | Cars & Trucks
I have a 1999 ford windstar and it's power steering start to whine about a week ago don't under stand why add more fluids helps but then it starts again also can hear air when i'm going to park and turn...
Check your Power steering lines especially where they may clip to a plastic holder on the frame. Water and salt spray like to corrode the line at these points. Sometimes you may need to disconnect the line and take it off and test it for pressure holding capability.
Make sure you use the correct fluid for your Brand. Sometimes the vanes inside the pump wear, especially if it ran dry. Then the unit will need to be replaced.
Last, when steering pivots, like balljoints wear, they cause more drag making the unit to work harder to steer. The pump can squeal under the added resistance.
Jul 30, 2013 | 1999 Ford Windstar
I the printer is not printing the top of letters instead it is dragging that ink across the paper
Look at the print head for jewel failure. AFTERMARKET ribbons lack requried lubrication for this style of printer. If you see wear, replace the head. There are remanufactured heads available that have a lubrication wick installed that helps this issue.
Sep 28, 2010 | OKI MICROLINE 521 Matrix Printer
We have windows vista and are unable to upload software that will allow you to load music onto the Sylvania SMPK8854B player
the program that is on the disk does not work at all i used win xp and nothing don't worry about the firmware it does not work i think thats why they stopped making them to load music just plug it in and go to my computer and look for drive letters sometimes G: or H: click and if a open space opens up just drag n drop a mp3 into it unplug player and look for the song you put on and play it the other drive letter will ask you to put in a disk there is no software to put on the music just drag n drop......
Dec 25, 2009 | Sylvania SMPK8854 Digital Media Player
On high speeds vehichle shiverring sometimes. and on high speed braking also,and dragging to one side,tyre worning out on the outer side of left tyre.
Sounds like you need a brake job (for shuttering when stopping), new tires because of un-even wear, and possibly an alignment (so the next pair of tires don't wear out. While they are checking, they should check the shock absorbers (struts). This is a fairly old car and will likely need stuts and alignment.
If money is tight, look into some used tires. The brake job is not critical until you hear noise. Keep the speed down if you can't afford the alignment and struts.
-Please rate this answer
Good luck
Nov 20, 2009 | 1994 Hyundai Excel
When I plug in my Lexar memory stick, and try to save a file to the removable drive (J) which is the memory stick file...it says I can't because it doesn't exist. Help?
Hi, Neil.
Look in "My Computer" to see if another drive letter was created when your memory stick was plugged in. Sometimes, another drive letter is created. Try dragging and dropping the file you want to save.
In case you are not aware, in each computer, the drive letter for a memory stick could be different, depending how a computer is set up.
Also, try in another computer to see how your memory stick works (if it's OK).
Hope this helps.
Oct 25, 2009 | Lexar JumpDrive Classic Portable USB Data...
Logitech Cordless Mouse Logo
293 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
