Question about Blaupunkt PCA465 Car Amp
My Blaupunkt PCA 465 700 watt ampifier has a problem, i turn on my truck and the protection light comes on for about a second then the power light comes on. Im using it to run my 400 watt 10" sub and when i turn the volume up the sub sounds distorted. The sub had no problem i checked it with my dads amp it runs fine. What can i do about my amp?
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Posted on Dec 31, 2008
SOURCE: My blaupunkt gta 460 goes into protection
Check the speakers wires for a wrong connection,check the speakers maybe they are not support the power of the amplifier,good luck
Posted on Jun 05, 2009
rteemon
  • 578 Answers
SOURCE: amp problem
could be one side of spk voice coil bad if they ar dualor rca problem
Posted on Jun 26, 2009
  • 47 Answers
SOURCE: i want to no how to tune a blaupunkt gta1350hp amp
U REALLY JUST HAVE TO TWEAK IT 2 UR OWN SPECS TIL IT SOUNDS THE WAY U THINK IT SHOULD THATS ALL PERSONAL PREFERANCE
Posted on Feb 28, 2010
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Protect led flashing with hit of bass
Try a bigger amp. This one wants to be turned down. But seriously the protect can act like sort of a clipping device when the unit is trying to amplify out of a certain range. The transistors may be getting weak and need to be replaced. That said I would move this amp to the midrange or the highs and get a little bigger amp for you low low's. Hope that helps.
May 08, 2010 | Blaupunkt GTA 260 2 Channel Amplifier 400...
I have a KAC 9152d with a red light on. what is the protect light and normal operating light colors? with the red light on the sound doesnt sound as full as it shoudl be. its running 2 12" alpine type R's...
your ampifier is in protect mode, try to dettache the speaker and turn on it.if the green ligh on ,one of your speaker is deffective but still the red light on theres something wrong with your amp.
Mar 03, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Jun 05, 2009 | Blaupunkt GTA 460 4 Channel Amplifier 800...
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
When powered on protection light comes on
ya i would say its not grounded right
Mar 02, 2009 | Car Audio & Video
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
Power on won't stay on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ΒΌ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Blaupunkt PCA465 Car Amp Logo
63 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
