Question about Panasonic KX-T7730 Corded Phone
Dear friend i am using a panasonic kx tes 824 i have three Q? 1. HOW CAN PROGRAM FOR CID BEFOR I AM USING NEC PABX ABLE TO SEE ALL INCOMING NO.(PHONE NO.) 2. IUR ALL 8 EXTENSION RINGING SIMULTANIOUSLY BUT I WANT ONLY RECEPTION PHONE SHUOLD BE RINGING. 3. urs pc console cant install becouse usb driver only for XP but ihve win2007 please help me
  • Panasonic Master
  • 2,460 Answers
This answers eaier in reverse order.
3. You find the drivers for the MC for your operating system. Our Pana dealer website has them, so I'd contact Panasonic for a solution.
2. The system needs programming. System programs 407-409 controls incoming ringing.
1. Did you install a 82493 CID card and programming?
Carl
Posted on Mar 26, 2011
Panasonic tes824 pinouts for TNG buffer
Try the parts department for your device at Panasonic . Com. support and parts.
May 10, 2014 | Computers & Internet
I just bought my panasonic units and i cant change the date model number of the phones kxt-7730 hybrid system tes-824 i want to change the date i have tried program 0 but it doesn't work i get the 3 beeps...
Since that's done from SYSTEM program 000, it seems likely that you 1. Aren't using extension 101 and 2. Didn't log into the system for programming
Try it again.
Carl
Apr 20, 2011 | Panasonic KX-T7730 Corded Phone
How do i programme extension on my KX-TES824 pabx?
It comes already programmed for lines, so you must be looking to program buttons for other things. How's that OM working for you? I can link you to the US version, it will program the same but you'll have different descriptions. Start on page 153 "Customizing your phone" :-) http://www.public.carl.airpost.net/Pana/TA-824/200_TA_OM_07-04%5B1%5D.pdf
Basically, you will press PROGRAM and buttons and use 1 + ext STORE for extensions and the right side buttons will be just access codes. Here we get an outside line with "9" and the phone numbers.
Carl
Mar 28, 2011 | Panasonic KX-T7730 Corded Phone
We have Panasonic KX-T7731 telephones in our office. we have three incoming lines and approx. 7 extensions. the phone co has assured me they've turned on caller id capabilities for all three lines but...
A 3x7 system with 7731 phones tends to show that you have a TA-624/824 series system. CID is delivered to the phones via a xxx93 card and programming. In a 624 it connects to the main board via a ribbon cable and is installed in the system cover. The 82493 cards plug into slots on the main board. Once, or if, the card is installed, it needs to be turned on via programming. At the very minimum, program 900 in system programming turns it on and there are other parameters that you can adjust in the 900's.
Carl
Mar 15, 2011 | Panasonic KX-T7731 Corded Phone
Is it possible to answer incoming call from kx-t ts 500 pone. we r using KX-T 824 PABX system
Either program your extension to ring or dial 40 when the call comes in.
Carl
Jan 23, 2011 | Panasonic KX-TS500 Corded Phone
Hi i need to add an callder id card to my existing tes 824 system. after i add the card physically to the 824. is there any programming changes required. If yes please explain
As a minimum, you have to turn it on in tab 9 or program 900 and 913. There are also some other programs to deliver CID to extensions.
Carl
Jan 11, 2011 | Panasonic KX-T7730 Corded Phone
Hi, I own a KX-T7730 and caller id hasn't worked from day 1. Thank you
CID on a 7730 reqoires 3 things, CID service from the phone company, programming on the sytsem, and a CALLER ID CARD. The card can only be added to TA-624/824, TAW-848, TD-816/1232, and TDA/TDE/NCP sytsems and has a part number ending in 93.
If it never worked from "day 1", then I'm guessing you either didn't order the card, or you forgot to inform your installer that you wanted CID turned on. Only the 50g and TA-824 models came with CID in the U.S.
Carl
Sep 15, 2010 | Panasonic KX-T7730 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Call history
If your looking to see the traffic in and out on a Panasonic system, it can be done through the SMDR port. There is a free program available called Phonelogger and a couple of inexpensive ones like Panalog and ProSMDR. All require a computer with a serial port to capture the data and all but Panalog has web based reporting.
Call history of incoming calls at your phone set requires a TA-824 system or higher (848/TDA/TDE) and a button or two programmed for CID Indication and CID select. You also have to have CallerID service from the phone company.
Carl
Dec 12, 2008 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
196 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
