Question about Dell Dimension 8400 PC Desktop
When i turn on my dell dim 8400 the fan races very fast i have to power down and start back up sometimes it takes 2 or three times then starts to work but after awhile it freezes up or if i wiggle the wires in the back it freezes up. is this the mother board or a driver?
  • 112 Answers
The motherboard is probably on it's last legs. For the price of buying a new motherboard, you can get a whole new computer, so that's the best option now.
Posted on Mar 26, 2011
  • 24 Answers
It sounds like a hardware problem. It could be due to overheating or a faulty port or connection. Do you find that the computer suddenly powers off? Do you have very frequent application crashes of Blue Screens?
    Guru:
  • Dell Master
  • 1,705 Answers
Normally, when the fan gets loud and races, it means that the CPU is getting too hot. The normal fault is that the case and ventilation block on the CPU is full of dust.
Disconnect the tower and take it outside or somewhere where a bit of a mess isn't a problem. Open the tower and look inside. Is it full of dust?
Using a dry soft bristle paint brush, CAREFULLY liberate any dust and fluff, if you have a hoover, brush to the hoover to remove dust.
The CPU is under a big metal blob with a fan on the top, Underneath the fan there are a load of ventilation duct in a metal block. See if you can clean them out, compressed air in a can is a good way. In conjunction with the brush.
Check all the vents and fans are clear of dust, including the PSU.
Once done, try it again, does it still race / lockup / close down.
If so, then you may need to renew the heat dispersal grease which is placed between the CPU and the Heat sink (Vented metal block under the fan).
The best place to find how to do that is look on Youtube for CPU changing / fitting / upgrading.
8400 dell hold power switch to get started
If it still acts up, compare wiring of the large motherboard Molex connector to the original. Dell used a variant that does not interchange. The enable wire is in a different location from standard ATX location.
If the processor is an AMD, remove cbattery and clear BIOS, and then try again.
Apr 07, 2012 | Dell Dimension 8400 power supply ** FREE...
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Cpu fan fast bios wont start
Run the Dell Diagnostics to test the Fan.
Check to make sure the fan power connector is connected to the mother board.
The fan could be defective.
Reset BIOS to factoiry default settings.
I hope this helps.
Good luck and have a pleasent day.
May 16, 2011 | Dell Dimension 8400 PC Desktop
Can not get computer to power back up no lights on front o rear just little light on mother board have dell 8400
Bad Power Supply, sscorbett.
Usually you have enough power to light LED lights, (Like the harddrive activity LED light for add-in cards, that you see on the motherboard), and spin fans, but Not enough power to turn the Processor on.
Dell Support >Dimension 8400 > Service Manual
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
Technical Overview > System Board Components
http://support.dell.com/support/edocs/systems/dim8400/SM/techov.htm#wp1052739
harddrive activity light for add-in cards (SCSI LED)
The Dimension 8400 comes with an ATX style of Power Supply, that has a maximum rated Wattage of 250 Watts.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Your Power Supply just has enough power to light that LED light.
Weak voltage power rail.
Replace the Power Supply.
[ There are three power rails inside that SMPS.
Switched-Mode Power Supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail ]
The ATX form factor for a Power Supply refers to the size, and shape of the case, for one.
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall.
The ATX power supply case in the Dimension 8400 however, is shorter in length.
It is 4 inches Long. (Depth)
Not an advertisement for the website, nor manufacturer.
Reference for the case size, and power cables needed,
http://www.cputopia.com/hp-400w-dell-dimension-8400.html
Scroll down to see the connectors of the various power cables needed.
You may have a Power Supply with these dimensions, and needed power cables, in an unused computer.
Perhaps someone has upgraded to a better computer, and has an unused computer that you can temporarily borrow the Power Supply for a test unit.
Make sure it has at least 250 Watts (Maximum rated wattage), plus,
1) 20-pin ATX main power cable. (Or a 20 + 4-pin ATX main power cable)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[ 20 + 4-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4 ]
2) 4-pin ATX +12 Volt power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Plus the various power cables needed for the Harddrive, optical drive/s, and computer case fan/s, if it/they do not connect to the motherboard.
Oct 21, 2010 | Dell Dimension 8400 power supply ** FREE...
I have no display when computer is turned on and
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 13, 2010 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 will not start.
no man try to take out the modem ( last pci slot on the botom of the board) and see if you have any luck if not you going to need a new motherboard thanks and good luck
Oct 11, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 - screen goes black or just freezes, no mouse or keyboard input works. Power down and then power back up works fine for about 10 mins then same problem.
Does the computer emit any beeps? If so, how many beeps?
One quick loud BEEP, at start up means that all is loading OK. If you get more than one BEEP sound, than you could have Memory ( RAM ) that is, or has failed. Sometimes, if one of the internal fans has failed or is failing, a computer will start up, and than shut itsself down again. Look for any error messages that may come across the screen. Get on another computer, and search for "computer beep codes". If you have the original manual that came with the computer, sometimes it will list beep codes in it. As it has been pointed out, it could be the hard drive also, check the beep codes, that is a good place to start.
Jun 18, 2009 | Dell Dimension 8400 PC Desktop
Dell 8400 runaway fan no diagnostic lights and very ocassionally it starts normally
Which fan?, the cpu fan or the cpu fan?
Most Dell pc come with a below average power supply. I recommend replacing your power supply with a better one. Do a search on Google for a good replacement power supply for you Dell 8400.
Please rate response.
Feb 17, 2009 | Dell Dimension 8400 PC Desktop
Dell 8400 boot up problems
There could be problem with the motherboard. You can try resetting the same.
1.Press F2 to enter the system setup.
2. Use the down arrow key and go to the option that says maintaince
3. Press enter and key down to the option CMOS defaults
4. Hit enter and reset defaults
5. Press escape and save changes and exit
6. check if the system boots up.
Before you perform the steps given above, unplug all external peripherals from the system like printers and webcams speakers etc. Your information is safe and there would not harm done to the information stored on the hardrive .
Thanks
proton
Nov 01, 2008 | Dell Dimension 8400 power supply ** FREE...
Dell Dim 8400 Issues
Hi Steve,
The problem that you are facing is most likely because of bad harddrive. As you have already replaced the RAM. To confim the same , run a diagnostics on the Hardrive. You can run the same in two ways .
Check if have the utilitu partision still left on the hardrive
1. Tap on the F12 key 5 - 6 times when you see the Dell splash screen , before windows starts to load.
2. Select Hardrive diagnostics or IDE diagnostics
If the above is no there , look for the dell Rescouce cd
1. Boot the system using the dell Resource Cd.
2. Select 32 bit diagnostics from the menu
3. Run a custom test on the hdd.
If the hardrive fails , replace the same, otherwise try swaping it connector cable with the optical cable.
Thanks
Proton
Oct 11, 2008 | Dell Dimension 8400 power supply ** FREE...
Dell Dimension 8400 PC Desktop Logo
220 people viewed this question
Alun Cox
