My screen in dark and i see to fix it. not a dvd drive problem. It's a monitor screen problem.
  • Computers & ... Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Mar 26, 2011
A90f dark dark screen
Use brighten controls on monitor to lighten
Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
Screen is dark maybe has to do with hard disk dvd cd mouse pad restart reboot
screen is dark maybe has to do with hard disk dvd cd mouse pad restart reboot
Dec 15, 2009 | Samsung 24" LCD Monitor 2494SW
DVD comes on but won't brighten up,the screens stays dark,no soun
Make sure all cable connections between the DVD Player and the television or monitor are well connected and then use the monitor to adjust brightness.
Sep 22, 2009 | Televison & Video
Sound works but screen is dark
In all likelihood, your monitor's backlight has failed. It can be fixed, but it will cost a good deal of money to do so. It may be cheaper to just get a new one.
If you want to fix it, take it down to an electronics store, and get a price quote.
Sep 19, 2009 | kawasaki PVS-10921 Portable DVD Player
RCA DRC6338 screen is dark
There can be dead lamp or invertor. Give it for some special guy who can fix this.
Aug 08, 2009 | RCA DRC6338 Portable DVD Player
Vertical lines in my laptop screen
Hi, that sounds like the integerated video graphics is going bad and it's not actually the screen. the zd7000's were known for video graphics failure. there was a lawsuit filed against hp for the zd models about a year ago to get a free motherboard replacement because of the video issue but it's too late to send it in now for the free repair. the zd models don't have a replacable video card in them like most laptops which the only way to fix the problem ould be to purchase another motherboard, you could try ebay but they're not that cheap. Rick
Mar 02, 2009 | HP 336084-6C0 - HP Pavilion zd7000...
Dark screen
This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen to dark, you have to check that if you still can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 24, 2008 | Nokia 445XiPlus 21" CRT Monitor
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
LCD monitor very dark.
The fault may lie with the ccfl inverter which basically provides a high voltage to drive backlighting for the lcd display. Not sure where you can get this part other than Sharp, but look round on the internet on this subject. I successfully repaired a similar problem with a portable dvd player using a ccfl inverter normally used to modify pc base units with neon-type tubes. Cheaply available at Maplin electronics,but may be a bit large to fit inside the monitor? Could be fitted outside as the wiring is quite long enough?
Jun 10, 2007 | Sharp LL T17A3-B 17" LCD Monitor
COBY TFDVD5600 Portable DVD Player without display in monitor
If you shine a torch into the screen and see the picture then the backlight has gone and needs replacing, although it would probably be cheaper to buy a new dvd player.
Dec 30, 2006 | Coby TFDVD5600 Portable DVD Player with...
Computers & Internet Logo
David Payne
David Payne
