Sanyo dp46840 LCD TV, Green power led is the only life the tv has.. I opened it up and checked all fuses and CAP's I tested the power supply and i get 5V stb ps_on 12v 15v As they are listed on the board. This power supply has the lamp ballast on same board.
  • Matthew Albert
    Matthew Albert Mar 27, 2011
    Yes i can turn it on and off,, but when the tv is off there is no red stanby LED, I dont know if there should be a red led on this set or not
  • Matthew Albert
    Matthew Albert Mar 30, 2011
    can you help me find the main board?
    sanyo
    1aa4b10n22900_c
    n7eee
  • 4,889 Answers
Are you able to turn it on and off even though you cannot see/hear anything?
Posted on Mar 26, 2011
  • 1 more comment
  • eagle338
    eagle338 Mar 27, 2011
    Well there should be an LED blinking if there was a power failure. Since you have nothing of that sort then its most likely to be the Main A/V board. So here's the plan. One of our experts has written a comprehensive troubleshooting guide. So instead of writing the wholething again I a linking you to it
    http://www.fixya.com/support/r5093881-lc...
    Try the mainboard diagnostics and let me know your observations
  • eagle338
    eagle338 Mar 30, 2011
    Well I have looked up every store I knew and it was out of stock everywhere. I will keep looking an dlet you know if I find something
  • eagle338
    eagle338 Mar 31, 2011
    Nothing. The way to go would be to contact Sanyo directly for the part as the board with the tuner n7EEE is nowhere to be found. Or atleast you can verify if any other alternate part is compatible with this tv.
TV won't come on at all. Getting power to where it plugs into the computer board. Beyond that I don't know how to test. Can you tell what to check next?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 26, 2014 | Sanyo Televison & Video
Sharp LED TV 3 years old stays dark on left side of screen for about 10 minutes after it is turned on. What could be causing this?
It seems to be capacitor{s}. Check the sharp website to see if there is any recall or special warranty on this unit.
Dec 15, 2013 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
Does my dp46840 need the shroud over power supply?
Not likely. The shroud is used for keeping out interferences. Not your case tho...
Jun 11, 2012 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
Sanyo dp46840 lcd tv,, Tv power led will turn on but no pic or sound,, i checked main fuse and cap's on psu, is there a problem with this model#?
Your main TV processor is locked up, unplug from wall for 40Min, and it will rest back to normal.
If that don't work, then you have power supply problems.
Mar 25, 2011 | Sanyo Televison & Video
My flat screen sanyo tv screen wont turn on. the green power light is on but not the screen. any solutions?
Try disconnecting the connector KBL on the main board as shown in my picture #DSCF0585 to see if the backlights will come on, if it does, the main board is bad.
Also check the voltages on the output connectors of the power supply.
http://s807.photobucket.com/albums/yy352/budm/SANYO%20TV%20DP26649/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 07, 2010 | Sanyo DP26649 26 in. TV
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Televison & Video Logo
546 people viewed this question
Top Televison & Video Experts
