Question about RCA R52WH73 Projection Television
We are having a similar problem with our RCA television that I have read about from other people. It appears to be the convergence problem because of the red, blue, and green on the television. My problem is that when we go to the convergence menu we cannot move the blue or red cross hairs. The arrow buttons will not work. Can you help?
    Genius:
  • 1,030 Answers
Ok this is an indication that you might have a problem with one of two different curcit boards. these cuircit are the "convergence power supply " or the "convergence amplifer board".. These 2 boards are above the main board in the set. Union electronics is where i purchased the last one i got. they are around 50 to 75 apeaice for them. You must have the exact model number with suffix number.
Posted on Mar 27, 2011
Comes on blurry cant read any small words at all and can just barley make out the picture.the color appears ok but the picture is blurres
Can you post a pic? It sounds like a convergence issue but need a picture of the screen to be sure if its convergence issue or not.
Jul 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
The picture appears like its in 3D and its all in pink and green. What would cause this on our RCA Rear projection TV?
The convergence causes this. First make sure it is the convergence by trying two sources such as a dvd player and a game system, or a cable box, even cable from the wall. If the picture is the same for all of them you will want to read the owners manual on convergence or call the manufacturer for a walk through.
May 05, 2010 | RCA HD52W59 HDTV Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How get auto convergence on RCA HD52W59YX38 to appear on screen
you can get the repair kit for your RCA at the following link. Its called the ITC222 and ITC222A convergence option missing repair kit, comes with detailed instructions. www.tvrepairworld.com
Sep 04, 2009 | Zenith R56W36 56" Rear Projection...
Rca color problem
does the convergence option still appear in the on screen menu or has it disappeared? Let me know and I will assist you
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
Getting double image in colors
this is a lost of convegence power. first check to see if you have the convergence option in setup menu. if you do not then i suggest you read the fl231 problem in the tips and trick section. otherwise there a good chance u would have to replace convergence power supply board
Mar 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
RCA R52WH73 Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
