Wireing diagram for a vh4d wisconsin engine - Computers & Internet
  • 794 Answers
Hi cruiseman 772,
You may click on this link for the Wisconsin engine wiring diagram. The parts illustration is for the VG4D engine, but can be applied to all models.
For additional helpful information you may visit this link. You may also download the manual on this link.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 26, 2011
I need the torque specs on a Wisconsin vh4d rods and head bolts
The Info You Are Requesting Can Be Found Right Here On This Site Posted By YADAYADA Do A Search And You Will See The Post !!
Aug 25, 2017 | Cars & Trucks
Got a m610 with vh4d wisconsin had fire at plug and it just vanished no spark at coil but have power to coil
Check wires. You have a short circuit. May need a new set of spark plug wires to include ignition wire.
Jan 04, 2015 | Cars & Trucks
Seeking a good place to find info on 4 cylinder wisconsin gas engines
You might try your local Ditch Witch dealer. The older trenchers used an air cooled 4 cylinder Wisconsin engine.
Oct 04, 2014 | Cars & Trucks
I need a wiring diagram for a Wisconsin v 4
what car, what truck
what model
which engine, V4 what size.what FUEL?
my wild guess it just an engine
ever consider asking wisconsin?
http://www.wisconsinmotors.com/
Jun 10, 2014 | Cars & Trucks
Why isn't my 16 hp Wisconsin lawn mower engine
there could be a couple different things causing a no spark situation. First, replace the spark plug and try it, if that isn't it disconnect the ground circuit from the ignition module, if that's not it then replace the module, if after you remove the ground circuit it works then you have a bad wire that needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 13, 2013 | Garden
I have a old tow motor w/ a wisconsin air cooled engine . I'm looking to change the 6 volt system to 12 volt system. looking for a basic 12 volt wiring diagram for GM alt. and wisconsin parts?
to change the points to electronic you will need to get the manufacturer of the distributor and contact them for a compatible electronic kit to replace the points or replacement distributor
to fit an alternator , get one with an internal voltage regulator ( talk with an auto electrician for the best unit --it is not necessary to go big amperage units so one about 35-60 amps will suffice and cheaper as well)
wiring will be the same as will fuses (neither volt sensitive)
gauges will have to be changed to 12 volt units
bulbs changed from 6 volt to 12 bulbs and switches will be the same as they are no volt sensitive
basically the same circuit can be used and the only place to be careful is the alternator wire to the battery and the charge light or volt gauge ( auto electrician can advise here )
starter motor will have to be changed to 12 volts and you will again have to get the replacement unit from an auto electrician as the bendix pitch , movement and mounting neck will be critical
wisconsin did not make electrical components but used off the shelf companies such as delco remy, lucas , bosch, ac etc for the accessories to the engine
it is an interesting project so collect as much information from auto electricians and web sites to help you
Jun 06, 2017 | Cars & Trucks
Computers & Internet Logo
1,505 people viewed this question
Alun Cox
David Payne
David Payne
