Question about M-Audio Producer USB Microphone with Session Recording Software
Sound problem I just purchased a m-audio producer microphone and it works fine when I record it. But, when I plug out the usb that came with the microphone, I can't hear any sound coming from the video that I just recorded... Is it the speaker that has issues or is it the microphone?
Ok well u need to save the music first den export it n save it on to ur computer den open it wit ur windows media player or wich ever player u have
Posted on Aug 10, 2009
All my vocals are recording late oner my tracks how do i fix that?
you need to make sure that you are using the M-Audio sync and not your sound card to sync voice. I guess you could use your sound card but make sure your instruments are using that sync too. most sound cards don't do well at recording audio in an environment that includes instruments being recorded at the same time.. If you mic has line in or instrument in, use it instead of sound card to record your instrument.
If what you are doing is singing along to a sound track then use the same sync for both.
Mar 17, 2011 | M-Audio Producer USB Microphone with...
My my sound really low not picking up sound well
Make sure you are using headphones and turn up the system volume so you don't get feedback.
Jan 04, 2011 | M-Audio Producer USB Microphone with...
Well, how do I get the producer usb mic to be mute while in playback???
If you disarm recording on the mic it should mute during playback. Just click the record button again to disarm it. Good Luck, Cody J.
Dec 17, 2010 | M-Audio Producer USB Microphone with...
Can't record clear sounding video on either my mini or my laptop.
A better idea is to use a digital camera with sound, switch to video record and make your video with that then copy that AVI file to your PC. But if you really want to use the PC make sure that your Audio source is selected in the recording devices section of audio properties as Microphone, then turn off mic boost. Slowly bring up your mic volume with the headphones attached until you can hear yourself clearly. Cranking it up too far will result in over-modulation and distortion. And finally, remember that most microphones included with laptops and Desktop PC's are cheap hetrodyne models with limited filtering and cheap plastic domes for audio pickup. The more you pay the better they get.
Something worth mentioning here.
I have actually had success recording with Cheap headphones on the Mic port before. Not headphone mic combos, but the actual Headphones. This gives you an idea of the sensitivity of these pickups.
Mar 14, 2010 | Computers & Internet
I cannot hear any microphone playback
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Feb 08, 2010 | Tascam US-122 USB Audio/MIDI Interface...
Plugging in Mic ceases sound playback
The drivers are working, but you apparently have a non asynchronous driver, meaning it either records, or plays, but has trouble doing both.
Gamers usually like their sound a bit beefier than the standard AC97 chip common with mainboards can produce, I would suggest first making absolutely sure your machine is clear of virii, etc,, turn off the windows sounds, because most earlier built-in sound chips cannot multi-client, and if you still have the problem, go for a USB sound box like the M-audio Transit, for around $100, it will give you high definition sound, both in and out, and you won't have to open your PC to install it.
Mind, I am not a shill for M-Audio, but for gamers, you really need the 24bit/96KHz out, to match your game's audio.
You will also find your games may run more smoothly, as the audio role is now in the little box, rather than your CPU.
The digital out can go to your home theater system, the 5.1 really makes it more fun.
Dec 08, 2009 | Computers & Internet
Crackly sound when recording vhs tape to disc
try new cables going from the vcr to the video capture (yellow red white)
Dec 01, 2009 | Pinnacle Dazzle DVC-100 DVD Recorder
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
M-Audio Producer USB Microphone with Session Recording Software Logo
289 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
