Question about Tricity Bendix AW1200 Front Load Washer
Tricity Bendix washing machine model WDR1041 w Makes niose like lock trying to operate then shows E40 on display
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
  • 135 Answers
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
Posted on Feb 24, 2009
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
What does e40 mean
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected
Jan 30, 2015 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
E40 fault n
E40 = Door open, door interlock, wiring or main PCB
Nov 07, 2012 | Tricity Bendix Washing Machines
Can i get a manual for bendix wd-1054 bx washing machine?
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 27, 2011 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Manual for tricity bendix 1000
Please try here:
Thanks.
Feb 24, 2009 | Tricity Bendix AW1000W Front Load Washer
WDR1041 spinning like crazy!
Usually washers go around on the floor because either they're overloaded or during the spin cycle the cloths are not balanced inside the basket. If neither of these is the case, you'll need to make sure the washer has been leveled properly. The only other thing I can suggest is to place the washer on a carpeted surface so it won't "slide" so easily.
Hope this helps.
Mar 13, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1200 Front Load Washer Logo
29 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
