Question about Microwave Ovens
I have just inherited a Stoves Richmond 900E and cannot get the induction hobs working.
Aeg glass induction hob error code ER 21
reset the microwave. Disconnect the power cord, by 1minutes, and try again,the microcontroller is confuse.
If the problem persist you can be problem with the main controller board, repllace, but read your owner manual section troubleshooting for identi the error. download from www.retrevo.com
God bless you
Oct 27, 2013 | Microwave Ovens
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
I HAVE A STOVES CERAMIC HOB 700CTH THAT IS SHOWING A FAULT 7A IS BEEPING AND FLASHING ON PLEASE CAN YOU HELP
The fault is on the PC board, capacitor C17. It can be replaced if you are handy with these things. Remove the hob and dismantle it to gain access to the PC board without turning it upside down. There are several screws which have to be removed, there are 13 spade connectors on the PC board, label these and remove them carefully. The capacitor has to be un-soldered and the new one fitted with the polarity the right way around. If this is not within your capabilities and you do not have the correct tools, have someone do it for you for a few dollars. A call-out for this fault could run into the $400 bracket and the part costs about $1.50.
Feb 08, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
I live in spain I have purchased a zanussi hob ZVT64BV and it has 4 electrical wires blue, black, brown and green/yellow why is this and how do I wire it up?
That's a H05BB-F two-phase cable - http://www.icc.it/view_cable.php?id=30 - and it's not intended for you to wired it up by yourself. There is of course a way, but the circuit has to be assessed for viability by a qualified electrician beforehand. The reason there's a two phase connection is that the current to the induction coil COULD be too much for a normal cable.
If that's the case, your kitchen circuit would become a fire hazard - the fuses would not blow, the differential wouldn't trigger, but the cable in the wall and behind your other appliances and furniture might catch fire.
May 29, 2010 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
