IF its an older SONY player, or an player with a KSS type laser in it ? then may be this can help
In the laser unit is a small spring remove this and also the overlying plate, a plastic block is seated at one end of the metal quide shaft move it very carefully in order to push aside the guide shaft as far as possible in order to free the laser in order to remove it, but is not strictly necessary to remove the plate the little spring only can save a lot of trouble with this type of laser.
The cogs are in that early years made to to delicately and get trouble over the time on the white axle excessive wear , the later models laser have it not anymore
If not Sony only to do a cleaning and silicon lubricate the guide shaft(s) of the laser again. can also help
Especially in the case of the mark Technics lasers which has a magnet transport, or Pioneer which often has a worm shaft.
I'm already did the solution CD cleaning.
