Question about Intex QUICK-FILL ELECTRIC PUMP, AC 110-120 VOLT
Where can i get the hose and nozzle replacement part for a intex air pump model 58627/68627?
  • 56 Answers
Unfortunately due to the inexpensiveness of this unit the manufacturer does not offer replacement hoses. Most sporting goods or big box stores do carry the unit for around $13us.
Posted on Mar 26, 2011
Got e90 error filter pump not working,noticed water not in lower clear hose called intex got new pump unit hooked up,bled air ran it still no water in hose What can i do, still under warrenty
Call Intex and follow up with their warranty precedures to fix/replace. Dont do anything that would void the warranty, atleast until they say they wont fix/replace it.
Jul 29, 2015 | Intex Pool & Spa
How do i backwash an Intex pool?
You can only backwash a "Sand" media filter.
If it is a cartridge element style, it needs to be removed and either hosed off with a pressure nozzle on your garden hose, or replace it.
If you have a Sand filter, you should have a multipart style valve that you would only turn when pump is off and place it into the properly marked "Backwash" position and then turn pump on for a few minutes, then turn back to "Filter" after rinsing.
Aug 05, 2014 | Intex Pool & Spa
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Where can i get hose and nozzle replacement part for a intex air pump model 58627/68627?
Actually Intex does offer replacement hoses with fill end attachments on their site. And pretty inexpensive to boot. $2-$3.50 at the time of this writing. I've added the link to the one I believe fits this model. As I have the same model.
Black Nozzle And Hose Parts Accessories Pumps Store Intex
As for the clip in part that the hose goes on, on the pump itself. Well, you'll have to contact Intex, like I'm about to do, to see if they have that part available.
good luck,
- chase -
Jun 02, 2012 | Intex QUICK-FILL ELECTRIC PUMP, AC 110-120...
Intex pump strongly pulls water in, but the flow into pool is very weak. Air lock or dirty filter is not the issue. Any ideas? Many thanks! Anna
It is likely that your filter is dirty. The filter's cartridge can be removed and cleaned with a spray nozzle on a hose. you will then need to reassemble, prime and restart. I hope this helps.
Aug 08, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Intex 633 lost suction
I have seen a common problem when customers change / clean their filter is that put the DRY clean filter in the skimmer box or filter holder and sometimes it can cause an "air lock"
Just take your garden hose put in the intake outlet of your pool and turn that baby on....If you start seeing air bubbles on the discharge end of the line most likely that was your trouble.
If the problem still persist then at that time look into pump repair / replacement.
Good Luck!
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My vacuum for my 18' intex pool doesn't work right. Goes good for first minute and then suction is very low. Keep getting air in line. How do I solve this?
Make sure you have your tube completly filled with water. hold one end at the discharge while pump is running when full make sure both end of hose stay under water while connecting. I also leave the bleedee cap unscrewed just a bit to let air escape from the system HAVENT HAD A PROBLEM YET
Jun 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
NO FUEL AT NOZZLE
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Intex QUICK-FILL ELECTRIC PUMP, AC 110-120 VOLT Logo
1,107 people viewed this question
Top Intex Garden Experts
Charles T Nevin
Charles T Nevin
Tom Chichester
Bill Boyd
Are you an Intex Garden Expert? Answer questions, earn points and help others
