Question about Jenn-Air JMC7000 Microwave Oven
Do you have the dimensions of the JMC700? - Jenn-Air JMC7000 Microwave Oven
I also have a Daewoo Microwave oven that quit working and I need a replacement. What Make and Model can I get that will be the same size for my motorhome.
get a tape measure and measure thea external dimension of the dead microwave
go to a retailer and measure the dimensions of new microwave ovens and one with the same or slightly smaller dimension will fit in
the power or wattage of the unit is of little consequence but don't get smaller than what you had but a a bit bigger will be good
Jan 05, 2017 | Daewoo Microwave Ovens
What are the dimensions of the following product Bosch Hbc84k51b
Check on the Bosh website. The Owners Manual should show the installation dimensions
Jul 23, 2014 | Microwave Ovens
Sharp R-1461a. What are dimensions?
The dimensions of your Sharp microwave model number R-1460, R-1461 and R-1462 are 29 3/4" in width 14 3/4" in height and 12 1/2" deep. Capacity is 1.1 cubic feet.
Sep 30, 2013 | Microwave Ovens
What are the dimensions for the Frigidaire PLMV168 microwave oven?
Hello D Timmen - Dimensions
  • Width : 29 7/8"
  • Depth : 19 1/4"
  • Height : 13 1/2"
Nov 23, 2012 | Frigidaire PLMV168 Microwave Oven
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
What are the dimensions of the Whirlpool microwave GH4155XPB?
Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
Dimensions of Jenn-Air Microwave Model M166?
The approximate dimensions are 22" W x 15" H & 15" D.
Jan 27, 2011 | Jenn-Air Microwave Ovens
Husband was using it last night (jenn-air jmc700)it's making a rough sound, there is a big brown kinda burn mark that extends from that small little piece on the right side that looks like it encloses...
It's arcing due to the food being attached to the mica plate. It needs to be serviced by an authorized technician. Don't use it or you can break the microwave valve.
Nov 03, 2009 | Jenn-Air JMC7000 Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
35 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
