Question about Tricity Bendix Washing Machines
Washing machine model WDR1041w make noise like lock trying to operate then displays e40
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Posted on Apr 04, 2008
jonniewalker
  • 1031 Answers
SOURCE: E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Posted on Feb 20, 2009
SOURCE: error messages displayed on my zanussi iz12
e40 the door not been closed e20 the drain hose may be kinked
Posted on Feb 25, 2009
  • 106 Answers
SOURCE: e40 fault code zannusi washing machine.
You could look here:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
Posted on Feb 28, 2009
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
When I switch on my washing machine AEG Lavamat turbo 16800 it displays E40
HI Mike.
THIS IS ALL I COULD FIND OUT.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
Dec 20, 2017 | AEG Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF80743. What does it mean and how can I fix it?
E40 relates to door lock faulty or not closing - you probably need a new door lock, but check the catch on the door hasn't snapped off first. You will also get E40 if you try to start the machine with the door open.
Dec 01, 2017 | Electrolux Washing Machines
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
Lavamat 72640 will not pass 24min on wash timer. sometimes it will show a E40 code but not always.
Hi.
on Oko washing machines E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced.
Regards.
Ginko
Sep 09, 2011 | Washing Machines
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
Electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Apr 09, 2009 | Electrolux Washing Machines
Electronic lock up
Error code is for door interlock...
However it is also possible that a track on your pcb that is connected through wires to the the door lock has blown.you will now need to replace the pcb aswell.this seems to be a common problem where doorlock blows pcb after failing
Jan 06, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
119 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
