How do you hook up the sub woofer and speakers to a Sony Briva TV
    Brigadier General:
  • 8,546 Answers
By referring to all applicable manuals. Do you not have them?
If the speakers are NOT self powered it will not work.
Posted on Mar 26, 2011
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
No sound from sub woofer
sub may be blown up, on protect, sub could be hooked up wrong. Did it work before and if so were all the wires hooked up the same? check to see if its being overloaded by blown speakers, check all speakers one by one, check your amp sub output with another speaker, I have had this problem form hooking up wrong.
Hope this helps...........
Apr 13, 2010 | Sony STR-DH500 A/V Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Oct 22, 2008 | Audio Players & Recorders
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Sub-woofer Malfunction
sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Dec 28, 2007 | Sony SA-FT1H TV Speakers
14 people viewed this question
 Grubhead
Grubhead
