Question about Proform Exercise & Fitness
I lost my key to my pro-form crosswalk 325. How can I use it without the key?
  • 16 Answers
SOURCE: How to do you adjust the belt on a Pro form crosswalk 380?
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Posted on Feb 20, 2010
roadtech7
  • 297 Answers
SOURCE: i PROPPED UP MY PRO
There is a knob about halfway down or up, depending on how you are looking at it. You need to lift up or push up a little bit to take the weight off the locking pin, as soon as the weight is of it should pull out about 1/2 of and inch. Be careful ALL the weight of the walk deck is now in your hands. Be prepared to lower it, and use your second hand immediatly anfter you pull the locking pin out. After the walk platform starts to come down, let go of the locking pin, it has a spring to pull it back, but the pin only fits in ONE hole in the prop rod, so it wont grab on the way down. Some treadmills have a dampening shock to allow the lowering of the walk deck slowly, and some do not. So again BE CAREFULL, this could hurt you if it falls on you.
Hope this was helpfull
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 10, 2010
  • 42 Answers
SOURCE: i purchased a weslo pro
hi weslo treadmill keys are mostly the same, i have seen some on ebay selling for under £15.00. or if you contact icon health & fitness 08451770512, these people are the main suppliers of weslo treadmills and parts. they are uk leeds based.
Posted on Nov 21, 2010
  • 95 Answers
SOURCE: I own a pro form Crosswalk model 405 and the
This is probably not your ideal solution but just in case it is helpful here is a list of the models of the proform crosswalk 405, if you select your exact version you can purchase a new owner's manual.
Posted on Jul 20, 2011
ercupa190
  • 12223 Answers
SOURCE: I lost my safety key
1) I do not recommend to do this. because you must bypass the electronic circuit and you can damage many ICS. if you do not have knowledge in electronic digital. Remember the treadmill fitness is very High Tech machine delicated.
2) will be better go to www. proform.com go to customer service and then parts & manual and order the parts, the best solution.
sincerely.
Posted on Nov 15, 2011
Can I purchase a key for a Pro-Form 400 crosswalk someone gave me
the 'key' is a small round magnet with a cord or chain on it,
to be clipped to your clothing for safety,
If you get too far from the handles the cord pulls the magnet off, and the machine shuts down, (hopefully before it throws you across the room). You can use a similar, magnetic 'key' from another brand of treadmill. or order one from sears
Jan 04, 2015 | Exercise & Fitness
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
When I plug in my pro form 370e crosswalk it doesn't turn on nothing happens
1) test the outlet wall, reset the c.breaker from your house, or tes the fuse if are blown.
if the problem NOT result and is o.k the c.breaker
2) test the power cord, for open
3) Eliminate any extension cord
4) test the main switch for open
5) reset the switch attached to the main switch.
6) tight any wires loose
7) reset the c. breaker or replace the fuse blown see the block.
God bless you
Jul 02, 2012 | Exercise & Fitness
My pro-form crosswalk 397 the track will not work. The lights display and it makes a sound but the track stays in place. I bought this on Black Friday and have only used it 3 times. Help!
INMEDIATELY LUBE the deck belt, maybe is WORN. and adjust the roller bearing see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
sincerely. God bless you
Apr 23, 2012 | Proform Crosswalk 397 Treadmill
I own a pro form Crosswalk model 405 and the instructions were lost in a move. How can I obtain a new copy?
Jul 20, 2011 | Proform CrossTrainer Treadmill
I lost my safety key for crosswalk advanced 525x. How can I turn it on without the key?
sincerely.
Jul 12, 2011 | Proform Crosswalk 500 Treadmill
I purchased a weslo pro crosswalk 7.8 it doesn`t have a safety key how do i know which key and where to get 1 thanks bill
Nov 20, 2010 | Weslo Pro Crosswalk 7.8 Treadmill
Jerky treadmill
Please check out this tip I wrote. Please let me know if you need anymore help.
Apr 08, 2010 | Proform Crosswalk 500 Treadmill
Pro-Form Crosswalk Plus Treadbill back leg extension
iconservice.com has free pdf downloadable manuals for proform.
Nov 12, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
143 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
