Question about JVC RX-772V
Auto Mute problem! I have an older JVC RX-772V home theater unit which has somehow gone to a "auto mute" setting for the radio. How do I get sound back? Perhaps users with an RX-774V models might work the same and have a clue for me? Thanks!
    Brigadier General:
  • 8,546 Answers
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/jvc/rx772vbk.html
Page 20. Read up on Auto/Mono
Posted on Mar 26, 2011
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
JVC STERIO RECIEVER MODEL RX-554VBX
on remote try to un mute it is a ch only on not a and b or none use a ch only go in main menu of system cheak auto mute turn off
Jan 30, 2008 | Audio Players & Recorders
Receiver comes on but have no sound tried the solution; but it still didn't work. What I am seeing is, in the upper left hand corner of the window in small writing says "mute auto" which is...
Mute Auto is for FM only. It mutes interstation hiss while tuning. Look for some other indicator that might reveal why the signal path is failing. Tape?
Have you tried the basics? Speaker test? FM only?
Sep 01, 2011 | JVC RX-554V Receiver
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Aug 14, 2011 | JVC TH-M303 System
The mute light Is on and the radio won't play. But if we play It threw the did player it works. How do I get the mute off for the radio?
If the MUTE is right next to the TUNED, it means the FM is muting inter-station noise until you tune a station strong enough to produce good audio. This has nothing to do with speaker MUTING.
Find FM Mode (page 14) and change it to Mono. Then you will hear the noise between stations until you find one strong enough. Install an anenna (page 3) and you might get strong enough signals to return the mode to Auto.
http://resources.jvc.com/Resources/00/00/96/LVT0141-001A.pdf
Jan 17, 2011 | JVC RX-558V
I tried restoring the sound by pressing Muting on master volume. Auto Muting still appears on the display and I can't restore the sound.
"Auto Muting" is for FM reception only and means it will mute the FM audio unless the signal is strong enough to provide decent audio.
Re-evaluate your symptom and corrective actions for relevancy.
Manual / Troubleshooting Page 31:
http://www.retrevo.com/support/JVC-RX-6000VBKJ-Receivers-manual/id/315bh050/t/2/
Dec 27, 2010 | JVC RX-6000V Receiver
I have a J JVC RX-558V. The mute light is always on so it does not play sound. I can't find the key sequence on the front of the unit to disable Mute?
Apr 19, 2009 | JVC RX-558V
No sound in FM radio
I had same problom and fixed by connecting an antenna to fm port
Jul 05, 2008 | JVC RX-6030V Receiver
Mute auto
I had same problem and connected antenna to fm port and it worked
Feb 13, 2008 | JVC RX-778V
599 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
