Question about Amana Refrigerators
The ice in the ice maker melts and refreezes. The food in the refrigerator drawers freeze and the top portion is warm. What is the problem?
  • 96 Answers
Sounds like the defrost thermostat is not opening and element is heating too long or the ice maker is sticking in harvest too long and the tray heater is heating too long. try turning off the icemaker for a day
Posted on Mar 26, 2011
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
I have a Whirlpool French Door Refrigerator Model #G17FVCXWY and the ice maker jams up about once a month (ice doesn't completely dump into the door bin, water refills into the ice maker, then refreezes to...
HI, we have the same problem with ours from time to time. It is a engineering flaw, bad design, the ice cubes are kept in the refrigerator section, which is about 38-40 degrees. So the ice cubes melt, the only way to keep it clear is to use ice cubes every day and not let then thaw and freeze.
Mar 11, 2011 | Whirlpool Refrigerators
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
I have a side by side refrigerator, automatic ice maker freezes.
What is happening is a partial melting and refreezing. Make sure the ice compartment door is kept closed.
Nov 19, 2009 | Refrigerators
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice in my ice maker bucket is melting and refreezing into a solid mass. I just looked at a recently made cube and it still has liquid in the center.
Yours has a 215846602 Defrost Timer, Located inside the fresh food compartment. I believe that it's sticking in defrost and you possibly need a new defrost timer.
Here is a photo location of the timer # 23 is the timer. I want you to turn the timer until the refrigerator compressor stops. Time it for about 25 minutes and the refrigerator should restart. If not then it's sticking in defrost so again turn clockwise slowly until the compressor restarts. That is possibly what is causing the melting and refreezing. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 19, 2009 | Frigidaire FRT18S6AQ Top Freezer...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
64 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
