Question about Vidal Sassoon Health & Beauty
We own aVidal Sasson VSCL907 Balder/Fader. The power cord is broken. Does this thing run on batteries too? The directions that came with it are long gone. Tried to get the back off by taking out the screws but it will not come off
SOURCE: COMPAQ Presario v6000 Died during Tstorm
My 6000 also died in a thunder storm with power surges.  Power seems to be coming in to the cord, but the ON/OFF button on the front does not turn the computer on.  Totally black screen, with no response.  Hoping for help too.
Posted on Feb 27, 2009
Benzschwagel
  • 33 Answers
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
Posted on Mar 25, 2009
  • 13433 Answers
SOURCE: compaq presario C501nr wont charge battery
The laptop's motherboard is most likely faulty and not charging the battery. Take or send the laptop to repair and or testing.
Does the laptop turn on without a battery? if it doesn't that confirm the fault.
Is the power plug loose from the board?
Posted on May 06, 2009
Geekman
  • 32281 Answers
SOURCE: computer runs off battery only not the power cord (battery is brand new)
You have a serious problem with the power and charging circuit. Normally if the battery is faulty the laptop can function with the power adapter plugged and running off the mains.
If a techo cannot fix without replacing the motherboard, then replacing the motherboard might not be a cost effective solution.
You salvage the hard drive by inserting it into an USB hard drive adapter case and use it as an external USB hard drive.
Sorry about this, you have very few options.
Posted on May 15, 2009
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
My monitor lot problem how want to change
So which one do you want to fix, Balder Multiboot software or your PC monitor ? If you want to change PC monitor you must consider various thing like the budget, screen size (inch), brand etc. which match with your need.
But if your software ware problem you can reinstall the driver or you can download from here :
http://www.downv.com/Windows/download-Balder-Multiboot-10239920.htm
Hope this help.
Feb 03, 2011 | HCData Balder Multiboot
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
Trying to run a digital projector from a car battery
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
May 26, 2010 | Black & Decker Black Decker 400 Watt...
How do i replace faders for the vmc 004
Hi you will have to open the mixer, make sure the power cord is not plugged in. The fader screws in from the back and the wires may be soldered. so you will have to unsolder the wires and re solder them to the new fader and replace and screw new fader in. Close mixer ..
Jan 31, 2010 | Vestax Vmc004 4-Channel DJ Mixer System
My acer laptop will not charge anymore when plugged in
Could be one or all of these things:
Old battery, defective battery, defective charger, broken ic power port.
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
it happens some times
dont panic
check the switch button is it on or not
check the power cord is correctly inserted
after that take the battery off
wait for 15 mins
put the power cord in the laptop
turn on the laptop
and try to move the lid up and down
i hope it will work for you sir.
Mar 25, 2009 | HP Pavilion dv4000 Notebook
OS X 10.4.10 Stuck Loop
H MerryAnn
I run Avid on my mac and have not experienced what you describe. Avid uses a lot of memory. The first thing I'd look at is do you have enough memory to run the OS and Avid. If that is OK check your screen res' (the system normally warns you if that is incorrect) If you have the install software try uninstalling and re-install to see if that helps.
It does not sound like a OS problem.
Regards
Paul
Aug 18, 2008 | Apple Mac OS X 10.4
Health & Beauty Logo
48 people viewed this question
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
