Question about Apple Power Mac G5 Desktop
Just bought a used G5 powemac, 2Gig Dual processors, early 2005, running fine until I tried to start from the install disk so I could partition the drive. Never got past gray screen, mac logo, spinning wheel. Killed power (didn't know how else to turn it off ) Started OK, went to system pref/startup disk, chose install disk as startup disk got the same thing. Now I get the same thing every time I try to start it: Startup chime, fans on low speed, goes to gray screen, Mac logo, spinning wheel, I can hear hard drive searching a little, soon fans go to high speed, never get past spinning wheel. It is like it cannot find a start-up disk.
  • 1 more comment
  • relax936 Mar 27, 2011
    OK, maybe I did not give it enough time to do it's thing from the install disk. But now, even without the install disk in the optical drive, it does the same thing when it used to start right up. I'll try firing it up again and give it as much time as it wants, and see what happens.
    Phil
  • relax936 Mar 29, 2011
    Thanks. I got it fixed. The install disk that I got with the computer was either bad or not the correct one for this computer. I got the box from someone who had several of the same model with different configurations. So the trouble was that the it was trying to find a startup disk that would not work. It was stuck.
    I remembered the start with option key to bring up startup disk selector panel, which showed it trying to start from the install disk. I switched it to the system on the hard drive, and it restarted normally.
    I loaded a universal version of system 4.6, ( the original system was 3.5 ) it started from that disk with no trouble, and I was able to partition the drive, and install system 4.
    Thanks for you r help.
    Phil
    I appreciate the help, and the solution did not work in my case. I was able to figure it out on my own though.
  • 112 Answers
When booting from a startup disk, it may take some time to load. When I reinstalled OSX on my Macbook Pro, it stayed at the gray screen with the spinning wheel for almost 10 minutes. As long as that wheel's spinning, something's happening. Give it some time and the OSX install disk should boot up.
Posted on Mar 26, 2011
  • Jeremy Mar 27, 2011
    I'd give Disk Utility a try. To run Disk Utility Repair:
    1. Start from your Mac OS X Install disc: Insert the installation disc, then restart the computer while holding the C key.
    2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu. (In Mac OS X 10.4 or later, you must select your language first.)
    Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.
    3. Click the First Aid tab.
    4. Click the disclosure triangle to the left of the hard drive icon to display the names of your hard disk volumes and partitions.
    5. Select your Mac OS X volume.
    6. Click Repair. Disk Utility checks and repairs the disk.
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I cant get ubuntu 11.10 to load onto my compaq nx9030 the disk runs fine but when i go to install it doesnt work
Use the Windows installer for dual boot. Easy! Or test as Live CD (no-install)
A full install may require partition and Linux disk / file format. Along with setup files destinations options. This a full commit install.
Nov 08, 2012 | HP Compaq nx9030 Notebook
I have 2 e-machines same year same version different model numbers can i use the same recovery disk on both
Theoretically, yes, but there may be caveats.
Intel components won't play well with AMD and some wifi cards want to balk at 'catch-all' drivers. However, if both your machines have a restore partition on the hard drive, then your idea will work just fine as the restore disk you have is just the install driver and boot sequence for your computer to use the restore partition.
Hope that helped...
Oct 25, 2010 | Computers & Internet
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
Will not start up. Sounds like airplane on take off.
When the computer hangs and does not get to the OS, the Fans are going to run at full power. sound like the OS is messed up. do this:
Boot to your install disk and the run disk first aid. If everything is OK, you may have to reinstall the OS. for the NO SOUND. you may have had the volume turned off. reset pram and see if that helps.
Jun 09, 2009 | Apple Power Mac G5
Can't boot 2nd OS system from partitioned HD.
go to add and remove software, deleted the last update from Microsoft. it should put you back to dual boot. try to install the update manually one at a time. find the one that prevent you from dual boot and discard the update. you should be OK w/o ceratin updates.
Jun 04, 2009 | AMD Athlon , 750 MHz Processor
Windows install problems
Be sure to have a correct partition to hard disk.Format the partition quick mode.
May 05, 2009 | Computers & Internet
Cannot reformat computer; no partition
the H drive is the manufacturer restore drive..where the factory setting, Driver and OS are installed ..since you deleted the drive and wanted to install new vista.
since you are using the OEM disk...boot your computer from CD...select custom install...if u are in stage that asking which drive are you going to install windows...click the more drive options in lower right...then create partition ...format..then install
Mar 16, 2009 | Gateway MX6920 Notebook
On my pc running win xp pack2 i want to install win 2000 pro. how can i do it? please suggest me.
You can either run a dual-boot system where you can boot into XP and Pro when you start your computer, or reformat and install 2k.
If you want to dual-boot you would need a blank partition on which to install it. Unfortunately if you do not already have more than one partition on your current drive, it would be difficult to split a single partition drive into adding another partition unless you are familiar with the tools required to perform such an operation.
However, if you only need to install 2k without having access to XP, all you need to do is insert the Win 2k disk and follow the installation wizard. When it comes to selecting where to install, it should show a partition containing winXP, which you can then install 2K to. Remember, all files on your XP install, including the operating system itself, will be removed. You would lose everything on that partition. If it is a single partition drive, anything on the drive is removed. You should back up any files you want to save by either transfering them to a different drive if you have one, or burning them to CDs/DVDs.
Select the partition you want to install to (if it's a single partition disk, there will only be one listed. If there are more partitions, you can select a different partition to install to which would allow you to keep XP), and I would recommend selecting reformatting the partition to NTFS.
Once it is done reformatting and copying files, it will ask to restart. Restart the computer, but do not press any keys upon startup when it pauses to ask to boot from CD. Wait until the 2K graphical installer loads from the disk, and then you can follow the setup wizard for 2K.
If you have any questions or problems, please add a new post stating them, and I will try to answer.
Dec 14, 2008 | Microsoft Windows Vista Ultimate Edition
Apple Power Mac G5 Desktop Logo
141 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
