My GE Electric Dryer Model DX2300EB0WW will turn and heat up when start switch is turn to start position, but won't stay on when switch is let go. Is the start switch also a relay? I can order replacement start switch for $38.00, does it sound like what it would cost for a switch with relay? What is the aveage cost for a professional repair for such problem?
SOURCE: GE Electric Dryer Heats up but does not automatically turn off
Change the sensor in the drum. Theres a sensor that tells it if there is moister in the enclosure.
SOURCE: Dryer is running, but no heat
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
SOURCE: GE electric dryer (model #: DRSR483ED2WW) sounds
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
SOURCE: GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
