Question about Honeywell Intellisense DT7550C DUAL TEC Motion Sensor
I HAVE A hONEYWELL DT-7550C MOTION SENSOR. It keeps being activated by a small bird flying across the front of the sensor. Is there a way to prevent it being activated by a small bird
The motion sensor on my 5 foot singing dancing Gemmy pirate skeleton isn't working. Where is the sensor located, and how do I fix it?
De-pant the skeleton and took a look down there in the foot where the inputs are. There should be a small circuit board. The proximity sensor is on a pair of green wires, yellow wires connected to the manual activation switch, connections to the various motors and the speakers up in the body, and a pair of long green wires that seem to be jumpered together. It's the proximity sensor that's likely at fault. Check to see if there is anything blocking the sensor. If nothing is blocking, check for loose or broken wires to it. Otherwise, you could remove the sensor and try to match it up at an electronics store and install a new one.
Jan 23, 2016 | Toys
How do I adjust a Honeywell motion sensor from a straight beam to a wider spectrum?
there should be 2 small adjusting screws on the unit. One adjust what you want and the other adjust when the light or sensor works.
Nov 13, 2014 | Cars & Trucks
How to disconnect
Ok their might be a screw on the unit to open it up. Once it is open their is 4 wires on it one for power + and one for ground - disconnect them and cap them off.
Ed
Aug 25, 2014 | Honeywell Intellisense DT-900 50 X 40 to...
As per request. re: reset/fix indoor motion detector.
on all the Honeywell or Ademco wireless motion detectors I have worked on the light will not come on with the cover in place, it is set that way to conserve battery life. If you want to be sure it is working properly arm your system and wait at least 4 minutes before walking in front of he motion then walk in front of it and see if it trips the alarm.
May 05, 2014 | Honeywell Ademco Apx32en Alarm System...
Do the symptoms of Jet lag vary depending on how many time zones Ive crossed?
Yes, people flying across few time zones may be able to adjust without noticeable effects of the time change. Those flying across many time zones will likely develop noticeable symptoms of jet lag.
Feb 06, 2013 | Luggage & Travel
In regards to bird cages, why is bar spacing so important? As long as the bird cannot fly out, then why does it really matter?
Inappropriate bar spacing can ultimately lead to injuring your bird. A cage where the bar spacing is too large could be hazardous to your bird, while a small distance between spacing will limit your birds view and also your view of your bird.
Aug 29, 2012 | Birds
What size cage should I buy for my budgies?
Even though budgies are quite small, they are very active and need space to fly around and exercise. Budgies need a minimum cage size of 18"x18"x24". Here is a sizing chart that should answer any questions regarding bird species and cage size, along with particular suggested brands of cages to buy.
http://www.bird-supplies.net/size-chart.htm
If I want to put out bird seed as a treat for the birds, how do I hang it? I don't want to use a table, I want to hang it from the trees.
There are recipes for homemade bird seed treats that involve suet or some other sticking agent that keeps it together so you can hang it in a lump. But I came across a very cute web posting with a recipe for a bird seed treat that is heart shaped! Check out this link http://kids.nationalgeographic.com/kids/activities/crafts/wild-bird-treat/
Aug 21, 2012 | Birds
Honeywell Intellisense DT7550C DUAL TEC Motion Sensor Logo
66 people viewed this question
Top Honeywell Home Security Experts
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
