Question about Fenix TK11 R2
Model TK11: light wont stay on when tailcap pushed.
Where do I find the model # on a flashlight I have?
On the packaging that came with it.
Written on the side, the tailcap or the lens housing.
In the confirmation email if you bought it online.
Why do you need to know?
Mar 07, 2018 | Camping, Backpacking & Hiking
How do i open the flash light to change the batteries in a duracell 500
This query is not really relevant to Cameras, now is it, dear ? Have you looked in the manual ?
Oct 01, 2017 | Duracell Cameras
How do I access the battery compartment on model 06443
To change the batteries in your flashlight, unscrew and remove the base tailcap, as the end that doesn't have the light. Remove the battery holder, replace batteries and then replace the battery holder in the same way that it was taken out (spring first).
http://ledmuseum.candlepower.us/fourth/gled.htm
Feb 21, 2015 | Garrity Camping, Backpacking & Hiking
Flashlight batteries stuck in body
There are a couple of ways that can free a cell that has expended and is wedged inside a light.
One is to remove the tailcap and rap the end of the battery tube squarely against a piece of soft wood like pine. It will keep from damaging the end of the battery tube and the shock my slowly work the cell out of the light until it comes out.
Another is to tie a strong cord around the head of the light so that when you hang it the tail end is hanging down. Remove the tailcap, of course, and go outside to a safe place where a flying battery won't hurt anyone or anything. Start swinging the light as fast as you can so that centrifugal force can pull the stuck cell out of the battery tube.
There are a couple of other things you can do if the cell is near enough to the end of the battery tube.. If you have a soldering iron and can reach to the end of the battery with it, try soldering a strong length of wire to the end of the battery and pull the cell out.
I hope one of these helps. ;)
Apr 09, 2014 | Gerber LX 3.0 Flashlight
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Stop lights wont stay on when i step on brake pedal on 2001 expedition
I had this same problem (brake lights won't come on when pushing on brake) I found that the brake light sending unit had come out of adjustment.Look under the dash by the brake pedal.There is a plastic threaded unit that needs to be pushed back towards the brake pedal lever.Careful not to push it to far or the brake lights will stay on. Hope this helps
Nov 12, 2012 | 2001 Ford Expedition
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I have a Streamlight Strion Xenon compact flashlight that has served me well for two years. Recently the 'twist to stay on' feature has failed. The 'push the tailswitch on' feature is still functioning,...
Ray, sounds like the switch has a problem. Streamlight is usually really good about fixing things. If you can drop by a Stream retailer in your area, they will probably give you a new tail cap. Or contact STREAM directly.
One thing, when you screw the tailcap tight, does the light come on? I have a SUREFIRE that does that, but I dont have a twist on Streamlight.
Sep 27, 2009 | Streamlight Strion 12V DC Only
T.v. wont stay on
hello it sound's like you have a power supply problem. need's to be replaced. "good luck"
Aug 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fenix TK11 R2 Logo
54 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
