Question about Kenmore HE2 Plus Front Load Washer
Washer is rattling like there is coins. checked the drain pipe and cleaned out but still making noise. gives a F-21 or Fd
  • 4,323 Answers
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it.
Hope this helps... Please post back if you need more information. Daniel
Posted on Mar 26, 2011
F-21 Kenmore Washer After cleaning filter
F21 is a long drain time warning. I have seen impellors in the pump get jammed with paper clips, bobby pins, coins etc. check the pump if you are using HE detergent.
Apr 30, 2018 | Kenmore Washing Machines
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
My front load washer is making noise and wont drain its spinning just not draining water
several pos solutions.coins or debri in pump.chk drain pipe to undersink drain is not blocked /ie cooking fat from used plates ,frying pans ect. or pump could be defective, happy hunting
Dec 30, 2012 | Washing Machines
Washer will not spin, filled up with water and stopped. When turn back on, it just humms then stops
The most likely cause is a blocked pipe or drain motor. This could be caused by an obstruction, such as a screw, hair clip or coin jamming the impellor inside the pump. Firstly, try to manually empty the machine of water. Take the drain pipe and lower it to a position below the machine itself. This should cause a syphoning action. Uou may have to give the end of the pipe an initial **** to start the flow. Remember to give the pipe a clean first with hot water and don't swallow any of the water.
Jul 31, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Makes a fairly loud noise similar to metal in drum .occurs intermittently. Appears to be related to draining.
Coin, bra-underwire, etc. Could be between rotating and fixed drum. Or may have flushed through to the filter and fouling the pump. Try the filter (remove, clean, check 'up pipe') first.
Good luck.
Jul 07, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
Oasis HE elite washer Sounds like coins rattling occasionally during spin cycle.
there are coins or small items in the pump. We used a wet dry vacumn to clean it out thru the drain hose.
Oct 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Zanussi FLE1116w won't drain
It sounds like you need to check out the pump. Remove the hoses from the pump and use a flashlight to look into the suction port on the pump for anything clogging up the works. Also check the pump impeller. This noise that you describe could be the impeller. If any blades are missing or broken or if you can't get the impeller to spin freely, the pump is defective and will need replaced. Hard objects like coins, pins, etc. can sometimes make it to the pump and can damage the impeller blades. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 30, 2009 | Zanussi FLE1416W Front Load Washer
LG WM-2277HB washer does not drain and make rattling noise.
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Apr 04, 2009 | LG WM2277HBW XL Front Load Stackable...
F2 error code
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
