Question about GE Dryers
Ge Profile Gas Dryer model number "DPSR473GWOWW" Loud squeaky and very shrill sound as it warms up the almost sound goes away just a tiny little cricket type sound remains.
3 Suggested Answers
SOURCE: Squeaky Dryer
Master_Tech:
I have the same model number and the same squeaky problem. I could use the same fix that you gave bebowser.
thanks
skuterbum@yahoo.com
Posted on Apr 16, 2008
heatman101
  • 43501 Answers
SOURCE: The GE Profile Harmony starts
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Squeaky GE Profile dryer model DPSE810EG5WT
There should be two wheels in the back that may have to be greased or replaced. There are two no friction pads that the drum rests on in the front that need to be replaced every once in a while. Go to searspartsdirect.com or appliancezone.com, with your dryer's serial number you should be able to find the parts.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DPSE810EG5WT/0432/0151200?pathTaken=&prst=0&shdMod=DPSE810EG5WT
or
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Feb 23, 2014 | GE Dryers
I get a loud scraping noise when I first start up the dryer
It sounds like the drum is off balance, the drum could be scrapping along the side of the dryer. Check for a loose bolt on the drum assembly. Once it starts running the drum levels out and the scrapping noise goes away
May 14, 2011 | GE DVL223GB Gas Dryer
When I try to use my gas cooktop, it makes a loud "pop" sound and has a big electrical spark that smells like fireworks then it flips the breaker.. Any ideas??
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hair
dryer do try it out and be sure there is not and liquid in it and put
electrical plug again to test it. If you still have the same problem, replace
the Spark module with a new one.
Here below you will find the
parts layout of your range for all the help you might need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
Dec 13, 2010 | GE 30 in.Profile JGP945 Gas Cooktop
The dryer has a loud squeaky noise whenever I turn it on.
heatman101
Aug 29, 2010 | GE Profile DPSR475EW Dryer
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Squeaky Dryer
the support rollers are drying out plz post your email i will send you the how to get to them and fix this you have to be handy though
Mar 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
