WVSR1060AWW GE 3.2 Cu. Ft. Super Capacity Washer The agitator barely works. It doesn't agitate enough to clean the clothes. It just started this and everything else is working fine. I was told this may mean the agitator spine is stripped. How do I fix that?
3 Suggested Answers
  • 1937 Answers
SOURCE: My Kenmore 3.2 cu. ft. Super Capacity Plus Top
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil (I replaced mine with gear oil from a local auto parts store).
Remove the transmission cover (8 bolts) and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Posted on Sep 13, 2010
  • 4 Answers
SOURCE: How do I remove the
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
Posted on Nov 08, 2011
Slow agitator
Sometimes it is a very simple fix.
Agitator dogs.
4 little plastic thingies that wear out so the agitator has nothing to grip.
I'm not sure if they are specific to each model washer but it's about a $5.00 try.
You have to take the agitator out.
I watched YouTube.
Pretty easy and far less expensive than a pro!!
It took 10 mins. The hardest part was getting the agitator apart, which takes elbow grease!!
Apr 19, 2014 | GE WVSR1060GWW 3.2 Cu. Ft. Super Capacity...
WHat is the capacity of the Whirlpool LLR9245BQ1 top load washer?
Hello there
  • Washer Type: Washer
  • Load Type: Top Load
  • Volume Capacity: 3.2 cu/ ft
is one of the better, super-sized porcelain-on-steel wash basket, combined with the Xtra roll action plus agitator, which ensures that your really big loads get really clean! The dual action of the Xtra Roll Action Plus agitator rolls even huge loads to the bottom of the wash basket where cleaning takes place. It can effectively roll over and clean twice the average size load! Plus, wash fewer loads to save time, money and energy! Ultimate Care washers offer both five and six speed combinations providing flexibility for the future in fabric care. Plus, the easy-to- use consoles makes it simple to select the desired wash/spin speed combination. And the enhanced agitator vanes ensure clothes roll over for consistent cleaning -
Jan 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you remove the agitator from a ge top load washer?
grab the bottom of the agitator and pull hard be careful not to hit yourself in the face
Sep 27, 2010 | GE 3.2 Cu. Ft. 8-Cycle Super Capacity...
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
