Question about Cyber Acoustics CA-2014 Computer Speakers
I have plugged in the speakers and can't seem to get our of sound of them . I think I hav e problem with the sound card. How do I fix it?
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 26, 2011
My mother bord is D946 GZIS CORE 2 DUE prosessor ,, its hav sound problm... i its hav no sound drive .. so tell me how can i solve ds problm???
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps you
Sep 16, 2011 | Intel D946GZIS Motherboard
No sound coming from both speaker
There are several things that could be wrong:
Your speakers are broken
Your speakers are not turned on
The sound cable is plugged into the wrong jack
The speakers are muted in Windows
The sound drivers are not installed or are corrupt.
Your sound card is bad.
Lots to think about. First ask if your speakers were working. If so, when?
Try a system restore back to when they were working. That should fix it. IF not, proceed:
Go into the control panel and click on sounds.
Select system sounds, choose a Windows event that has a sound assigned and try to preview it. If the preview arrow is grayed out, then the sound drivers are at fault. If you have a black arrow and you click on it and it seems like it's playing, then check for mechanical problems.
If Windows thinks it's playing and it isn't, the system restore thing should fix it. Or try another set of speakers to see if your speakers have failed.
Apr 17, 2011 | Computers & Internet
I can not hear sound what problem of this?
Several things must be in place to hear sounds on your pc.
You must have speakers - the kind you not only plug into your pc but you must also plug them into your wall to have a louder sound. OR --- you can use head phones. The headphones plug into your pc sound card.
You must have a sound card or onboard sound
You must have a sound card DRIVER.
These three things and some reading will get you going
Best of it
Rice @ Fix Ya
Dec 14, 2010 | Computers & Internet
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
I plugged my speakers in to the sound card and it
Hello!
You must try 2 options.
Try uninstall sound card drivers, reset comp., and again install sound driver.
In second case you must try new system, with full format hard drive, because you can have trouble with virus, and that is only safe way.
You can also try another sound card, but I think that is you sound card OK.
Nov 02, 2009 | HP (400745-001) Sound Card
Hi, They suddenly stopped working, think I
Try another speaker set.
If this does not fix it, then consider the sound card if it is removeable, get a new one. If it is internal, turn off the sound and install a sound card.
Oct 05, 2009 | Dell A525 Computer Speakers
There's always a bzzz sound coming out when plugged in.
if there's buzzing coming out, there's probably a rip in the actual speakers. Something is torn on the inside thus the weird buzzing noise.
Unless it was a zzzzzzzzz...... noise then there's probably some sort of interference. Possibly cellphone close by, or some other magnetic thing to create that annoying sound.
Apr 21, 2009 | Creative Labs SBS-260 Computer Speakers
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
X-530 Not working!!
Ensure that your sound card setup/diagnostic software can correctly recognise your speakers. You will need to know what sound card is in your PC. Be carefull with PCs that have sound cards built onto the mother board and that also have a seperate sound card. Ensure the sound card you want is the one you have plugged the speakers into and ensure you have disabled the other sound card and its software.
May 02, 2008 | Logitech X-530 Computer Speakers
Cyber Acoustics CA-2014 Computer Speakers Logo
103 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
