Question about LG 37LD450 37 in. TV
My lg 37ld450 seems to be stuck in sleep mode, it was working the night before but now whenever i press the on/off button, the red light turns on and off rythmically which makes me think its in sleep mode. i cant turn it on, what do i do?
  • 214 Answers
SOURCE: my power went out last night and now my lg tv will
check the back of the set and see if there is a red reset button, or try unplugging the set for a couple of minutes then plug it back in. If you have cable or dish make sure these have reset properly,
Posted on Nov 29, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
freelance-au
  • 131 Answers
SOURCE: 61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
Posted on Mar 05, 2010
  • 979 Answers
SOURCE: my lg 50pc3d will not turn on the power light
Hello sir, hi, the symptom you have describe can be traced on the Power Supply board, either minor problem such as loose connections and screws, or a major one that needs replacement of the entire Power supply board. You choose:
Have a look, and check for loose contacts, screws that needs to be tighten but you need to open up that big TV.
Or if that does not solve the problem, its the major one, needs to replace the entire PS board.
Posted on Mar 13, 2010
  • 8457 Answers
SOURCE: LG shut off by itsself
Tries unplug,replug the tv back like an hour later.The tv,now it will resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Try website Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 25, 2010
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
My LG optimus keeps getting stuck in sleep mode. When I turn it on it seems fine but once it enters sleep mode it won't turn back on. I have to restart the phone to get a picture again. Any tips?
Is it ''sleep'' mode or ''Hibernate'' mode? If ''Hibernate'', then that is the problem. Turn off ''hibernate.'' If it is in fact just ''sleep'' mode, check to see if it is set for ''enter password to exit sleep'' _and_ you don't have a password set up... then either create a password or set it so that it does not require a password upon exiting sleep. Also, you can always resort to resetting everything to ''default'' settings. (This will not effect any data on the phone, and you can take your time setting all the settings ''just right'').
Jan 02, 2015 | LG Cell Phones
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
Asus k50 will not start
If the light on the pc, not the power supply is orange this usually means the pc is not comming out of sleep mode. Try the obvious and restart it. If that does not work, attempt starting in safe mode and go to your control panel and turn off all power saving, screen saver, and sleep mode options.
Sep 24, 2012 | ASUS K50 Series K50IJ-G1B NoteBook Intel...
Wont recover from sleep mode after depleted battery
plug out the batter and give the AC. turn it up. any light? if you dont have you have a problem with Mainboard that doesnt let the electircitiy goes in.
of course i am assuming your adapter is working :)
May 30, 2009 | Acer Computers & Internet
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Night Service Button
Sounds to me like "inspect" might be the button programmed on the phone. IF the button is labeled "night" then you can reprogram the button.
press "SPKR # 0 0"
Press the button labeled "Night"
Press "* 3 9"
Then press the "home" or "exit" button.
See if that works...
Nov 28, 2007 | Lands Phones
LG 37LD450 37 in. TV Logo
