I have just connected a new computer ( HP Z200 Windows 7 ) to my dell S2209W monitor, but the monitor is blank other than a little blue box whch reads: No VGA cable. It was working fine with my previous computer ( Compaq Windows XP ) please help :)
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
My dell monitor is too dark
There is a small light behind TFT screen which must have gone bad
Feb 15, 2013 | Dell S2209W Monitor
No a problem I was wondering if this monitio will connect /work w/a dell computer ?
As long as it has a little blue plug or a little white plug on the back of it, it will work with any computer.
Feb 28, 2011 | Polyview MNTR |17'LCD V17D Monitor
My dell monitor screen, s2209w, is blinking and asks for password
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Aug 01, 2010 | Dell S2209W Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
I have a Dell Monitor S2209W and it does not auto adjust when I change the resolution. It is connected to is a Dell PC running Windows XP. If I do not set the resolution to 1920 x 1080 the whole screen...
The S2209W is designed to be run at the optimal resolution of 1920 x 1080 http://support.dell.com/support/edocs/monitors/S2209W/en/ug/optimal.htm
selecting a lower resolution will result in generally unsatisfactory appearance. This is due to the hard wiring of the pixels in LCD screens.
What you can do to abate the text being too small is adjust the DPI setting from the default of 96 to 120, or even 144 if you need real large text
Oct 04, 2009 | Computers & Internet
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
Poor Resolution on Monitor 2
what u can do is.... 1) Backup your Registry first
2) go to Regedit....Start>Run>Regedit
(this is assuming u have latest Nvidia driver's installed)
HKEY_LOCAL_MACHINE/Software/NVIDIA Corp/Global
In global. Make a new KEY called NVTWEAK
In this key, make a new DWORD value called Coolbits now, change the value of coolbits to 3.
Now when you do into Settings for GFX and advanced settings....you will notice a CLOCK SPEED/FREQUENCY tab. Change them.....go up like 20mhz....or 30 or 50...too high will screw ur card...too low isn't worth the trouble.
So, slowly go up little by little until you notice s--- on ur screen that's dodgy..then just fall back behind that Freq.
Also....another fan taking heat AWAY from the GFX card wouldn't do any harm either.
Don't forget to rate this solution.
Feb 20, 2009 | XFX GeForce FX 5200, Graphic Card
Can't reset computer for HP 24" W LCD
I would suggest try rebooting in SAFE MODE and the right clicking with the mouse on the screen go to properties then setting and change the area of the screen
Jan 22, 2009 | Computers & Internet
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
