Question about Cst Berger 56 CST225N Pentax Total Station Reflectorless
I have a Pentax V-325N total station and it has just simply frozen..... it will not respond to any commands not even the turn off switch. \the battery is well charged, I AM AFRAID NOW THAT IF i REMOVE THE BATTERY THAT i WILL LOSE THE DATA i HAVE SURVEYED. cAN YOU HELP............PLEASE
Phone will not respond but has power
If this is a smartphone, you can typically hold the power button down for up to 20 seconds and it should hard reset if it is frozen. Another trick would be to simply remove the battery if removable.
Nov 16, 2013 | Computers & Internet
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Radio works on one station all other controls apart from volume seem frozen wont search for other stations,x-bass wont work and screen shows t>je:xw can anyone help.tried switching on and off tried...
you may have a bad switch. sometimes if a switch does not close completely, the microprocessor thinks it is getting a command and will not respond to anything else, locking it up.
Mar 02, 2011 | Blaupunkt San Remo CD32 CD Player
White screen, not responding
see if the lens is zooming in & out. If not check for broken pcb or lens assy.
May 20, 2009 | Pentax Optio A30 Digital Camera
Cursor freezes or is eratic
I believe this would be caused by a couple of things. The first, and most likely is probobly that it needs a driver update. If this is not the case, go to computer properties(Right click 'My Computer', then hardware (if xp) then device manager. Go to pointing devices and uninstall the mouse driver.
Yes, you will be unable to control ur laptop. Simply turn off and then the computer will recognise the maouse/mousepad and install the driver.
The second problem could be to do with a nasty little bug out there thats causes both your curser and/or keyboard to act erraticly.
May 19, 2009 | Acer Aspire 5520-5908 Notebook
5th generation iPods hose up while using Altec Lansing IM600
Yes, the docking station is damaging the iPod. The vibration when used load is causing damage to the iPod. If you notice, the iPod will only freeze when it is playing load in the docking station. To avoid the problem, you'll need to play the music at a lower sound with less vibration. Once I began to play my music at more reasonable sound levels, I discontinued the problem. Very disappointing solution...but it is the answer. I too called Altec Lansing. They are not aware of this issue...I told them to search the internet - it's all out there.
Mar 21, 2009 | Altec Lansing Inmotion-IM600...
Pl inform address where I acn get the following
the first place i would look is at a radio shack or look online for local places
Jan 30, 2009 | Pentax Optio 60 Digital Camera
First Frozen At The Logo, Now No Screen At All
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
good luck
please mark the post with a fixya
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Gigabeat 40GB screen frozen
well, it would be really easy to take off the battery. The battery is simply plugued with a little 3-pin wire, u just pull on it and put it back in. Now to open that gigabeat, its pretty easy. I even got some images for u. Go at this website (its for the F10 and u have the F40, but its the same thing): http://www.angelfire.com/bug2/gigabeat/
Mar 24, 2007 | Toshiba Gigabeat F41 (40 GB) MP3 Player
Cst Berger 56 CST225N Pentax Total Station Reflectorless Logo
196 people viewed this question
Top Cst Berger Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Berger Measuring Tool and Sensor Expert? Answer questions, earn points and help others
