Question about Mansfield Plumbing Products Home
My Mansfield toilet flushes but only 1/3 of the water in the tank flows out during a flush and the bowl does not get enough water to flush everything.
  • 349 Answers
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
Posted on Mar 28, 2011
Misbehaving toilet
The included link should provide some help in determining your specific design. Depending on your specific design the flapper is a critical component in controlling the amount of water released from the tank during flush.
The appearance of water flushing is in fact created by the siphon action of the water falling down through the drain pipe.
Any restriction in the down stream drain flow can give the appearance of a bad flush. So the problem may not be flush, but a restriction in the drain pipe, or trap-way or outlet.
Using a bucket filled with water pour water quickly into bowl and observe the flush action. Compare the action with another toilet using the bucket. If the flush appears adequate and the water from the tank flows slowly check for salt buildup at the nozzle end of the outlet from the tank into the bowl.
In the design below there is a transfer tube that injects air into the trap. This provides a vacuum to promote the siphon during flush. A leak or failed seal in this transfer tube would result in poor flush.
If drains are slow, particularly if you hear a "gurgling" sound at fixtures during draining, I'd suspect that the building vent system is blocked restricted. A restricted drain is much more likely than a restricted vent. Small children are likely to have placed non biodegradable toys etc into the toilet and they may have gotten trapped. Build up in the vent pipe is also common.
In this example ice is blocking the vent!
The link provides design information and partuculary flapper considerations.
http://www.watermgt.com/Determing%20design%20flow%20of%20toilet.pdf
Hope this helps? No comment
Mar 18, 2017 | Home
Poor draining toilet checklist
1. Is the toilet plugged or partially plugged. I have removqed toothbrushes, combs, toys etc. from toilet traps so check for any obstructions.
2. Rust and scale buildup. The buildup of rust , sediment and or scale in the internal passages of a toilet can greatly affect their performance.clean the small holes under the rim with a small piece of wire. Use Limeaway or CLR to remove rust and scale. put some in the tank and flush toilet. Let sit for a while and repeat.
3. Improper venting or plugged vent. A toilet needs a properly vented drain to work correctly. Check the vent to make sure it is not plugged or in the northern climates frosted shut.
4. Mechanical issues. Is the flapper lifting high enough when flush lever is flipped. Is water at correct height in tank. If it is a pressure assist is water pressure high enough. Is pressure tank waterlogged.
These are just afew of the many things that can cause a poor flushing toilet. Hope this helps.
Jun 28, 2012 | Mansfield Plumbing Products Mansfield...
Toilet is not flushing
sounds like you need to adjust water level in tank,take lid off and check if theres enough water to flush should be a water level line in tank.
Sep 24, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
When flushing the toilet, there is not a lot of "push" behind the flush. I'm having to flush two times, regardless of what is in the toilet.
It is normal for these useless new tanks to do that. Won't even flush a piece of paper. Pull off the lid and make sure the little hose is in the overflow pipe, and raise the water level as high as you can. take out all the bricks and water bottles, and bowl cleaners. Then give it a try. It might do a bit better. Hope this helps.
Jul 03, 2010 | Mansfield Plumbing Products Mansfield...
How to fix fill water shooting up and over when flushing?
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
Mar 19, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Our Toto bowl does not fill up enough after flushing unless the lever is held down. What do I do to fix it? We have well water and a bit of mineral does build up on the fill tube.
The only adjustment available is to control how full the tank will be for the next flush. The water that runs down into the bowl after flushing comes through the same valve that fills the tank, so the problem (and solution) is entirely with the amount of water that runs into the bowl while the tank is filling. The tank is filling sooner than enough replacement water can run into the bowl. Make sure that the tube (usually a 1/2 inch rubber tube) that runs from the float valve to the pipe that fills the bowl (usually a 1 inch pipe with an open top) is actually delivering all of it's flow down that pipe. If the flow of water being delivered by that tube is slow, you will have to find and eliminate the restriction. You might be able to pull of the rubbber tube off of the float valve and stick a small drill bit (just using your fingers, not a drill) into the fitting where you pulled off the tube.
Mar 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. However, if I pour a 3 gal bucket of water into the toilet bowl, it flushes just fine and the water level...
Alot of times this problem occurs when there is not enough water in the tank behind the seat and bowl. Lift off the tank lid and see how much water is it, It should be near full.If it is not your problem is not enough water.
Feb 21, 2010 | American Standard 2071.016 Heritage One...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Dec 15, 2008 | American Standard Home
Home Logo
497 people viewed this question
Top Mansfield Plumbing Products Home Experts
john h
bobalix
richochet
Are you a Mansfield Plumbing Products Home Expert? Answer questions, earn points and help others
