Print spool turned off - Office Equipment & Supplies
    Scholar:
  • 84 Answers
Print Spooler is a Windows service that is involved in the printing process.
In order to turn your Print Spooler service back on: click Start --> Control Panel --> Administrative Tools --> Services
In the Services window, there will be a big list of services. Scroll down until you find the Print Spooler service. Double click on it, set the Startup type to Automatic and click the Start button to activate the service.
Let me know if you need more help.
Posted on Mar 26, 2011
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Troubleshoot/hpDeskJet 895Cse printers,how to cancel a print job
Print jobs are kept in a print spool on your computer. Turning off your printer only clears the printer. To clear the print spool on a Windows type computer, look for the printer icon on the task bar, lower right hand corner of the monitor. Double click on the small icon will open the list of pending print jobs. Select the one you wish to delete, then cancel the print job.
Feb 18, 2015 | Office Equipment & Supplies
Hi my printer will not print. it is saying printer spool error.
> spool error
S.P.O.O.L. == Simultaneous Peripheral Output On Line
The "spool" is a combination of disk-space on your 'C:' drive, and software to "accept" the print-image (as fast as MS Word can create the print-image), and save the print-image to disk-space,
so that MS Word can report "print completed", so that you can use MS Word, instead of waiting until the physical printing has completed.
Then, the printer-spooling software will read from the print-image file, and send it to the printer, only as fast as the printer will accept it.
Feb 05, 2011 | Xerox Office Equipment & Supplies
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
Xerox 4150xf Workcentre is not working. It seems
OK. I was curious because it is an XF machine. F denoting a fax.
Try in the print queue on the pc to spool the document first and then print to see if that helps.
I don't have access to the xerox documents (EDOCS) anymore but I would look at the memory. If you have one spare, swap it out to see if that helps.
Nov 20, 2009 | Xerox Office Equipment & Supplies
When I print, it says spooling
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options: Click Start then select Run Type the word "net stop spooler" then "net start spooler" Then unplug and replug the printer while its on.
Josh
Aug 18, 2009 | Kodak ESP 5 Printer
I cancelled a print an hour ago and it is still deleting
turn off the printer
go to the computer and click on start>>control panel>>administrative tools>>services.
select print spool and right click to stop it.
now opne the printers and Faxes. open the printer properties and delete all of the print jobs.
go back to the service and restart the print spool, and turn on the printer.
Jun 07, 2009 | HP PSC 1410 All-In-One InkJet Printer
Deleting Files from spool after they have printed
see your Spool settings, Set Print directly option and try.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
Problems deleting printed files from the spool
Navigate
Start-> Control Panel -> Printer
Right click on printer icon and select properties
Find out Advance settings. See Spooling, Select Print Directly and try.
Although your driver looks like incompatible but above will fix your problem.
Thanks
Iqbal
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
k24674
jasbo
jasbo
Marvin
Marvin
