My barracuda 7200.7 120gb hdd won't work with power cord inserted but take cord out(of hdd) and computer fires up?
    Genius:
  • 1,689 Answers
There is a possibility that the power resources of your computer (specifically the power supply) cannot give enough power to the whole PC plus the new HDD, there are lots of options that you can do to get this resolved, some are you remove components in your computer taht is not being used, secpially the one that is plugged to your power supply,
OR
get a power supply that have larger wattage / power capacity.
hope that helps, good luck on this one, just let me know if you should have other questions.
Posted on Aug 04, 2008
Bios cannot read hard drive
Hi Robert,
IT could be that the Barracuda drive is formatted for boot up. I would boot up with the drive that boots, and make the Barracuda a spare drive, so you can go in and first see if has any issues as a drive,(meaning sector 0 errors, and if you can access it, then you can format it as a boot up drive, or get what data on that drive off for your friend.
Good Luck Mark
Sep 01, 2014 | Seagate 1TB Barracuda Internal Hard Drive...
Recover data from seagate barracuda 7200.10
External hard drive case, which comes with its own PSU AC/DC power pack.
They come in IDE and SATA flavours, some with extra cables to convert IDE<>SATA.
Take HDD with to computer retailer so physical dimension can be matched.
Sep 07, 2012 | Seagate Barracuda 7200.10 ST3160215AS -...
I have a seagate barracuda 7200.12, 500 GB, HDD, as suddenly it is not working nothing is showing up, some type of clicking sound is also coming from it. the computer detects the hdd, but nothing is...
If you have another computer, you could try to plug it in there as a slave/secondary drive so that you can try to see if My Computer would still recognize it. If it works, then great, you can still do backups. If not, and you really need that data, you might want to get the services of a data recovery company.
Jul 29, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My SATA HDD Seagate Barracuda 7200-12 no detect on Biostar P4M80-M4 Motherboard, it is something wrong with my motherboard?
your hdd is crash or may be problem on power supply connector and cord connector try to replace it.
Apr 18, 2011 | Biostar : P4M80-M4 Socket...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Seagate 7200.8 300 gig harddrive just stopped working. No noise, no nothing. bios and o.s no longer see it. I need it to work
Your hard drive is maybe faulty. But before you consider that, try this thing first. Connect your hard drive using the other power cord from your power supply. If you see the HDD led is working, the red one in CPU casing, then it has power but if still no detection from the computer then probably your drive is faulty. Bring it to nearest computer repair center in your place and get it fix there.
Nov 01, 2009 | Seagate Barracuda 7200.8 300 GB Hard Drive
Barracuda 300 keeps turning itself off every afternoon
check the power settings from control panel.. try to select the "always on" option for your computer.. if that doesn't work.. check the BIOS settings.. see if there are any option for HDD power saving there..
Jul 02, 2009 | Barracuda Networks Spam Firewall 300...
Seagate hard drive moved from one computer to another won`t boot
Now this is just my opinion but i tried to do the same thing one time and it would not work so I was left with one choice. Do a fresh install, I bought a second hdd and did a fresh install then plugged my original hdd in as a secondary so I could still access my old files.
Feb 12, 2018 | Seagate Barracuda 7200.10 ST3160815A -...
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
Open Questions:
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
