Question about Saeco Talea Giro Espresso Machine
Saeco Talea Giro Plus, descaling following instructions step by step. In step 12 the descaling light did not turn off. The warning light came on as indicated. In step 15, pressing the descaling button turned off the warning light, as it should. But now the descaling light stays on and the machine is disabled. Nothing seems to work even turning it off, unplugging it, pushing the descaling button, or pushing the hot water button. What will fix it? Thanks for the help.
  • andyschai Mar 26, 2011
    Well, I fixed it myself. I let the rinse cycle going and going until it finally decided to turn off the descaling light. It went through 3 or 4 additional water reservoir refills, but it ended up all ok.
    This was the first problem I encountered since it was new 8 months ago. I hope it's the last.
  • Emily Early Kehrberg Jul 20, 2012
    I just had the same issue, after 1.5 years with no problems. I followed the advice above, ran it through 2 additional rinse cycles, and the light reset.
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Posted on Apr 20, 2011
Also, be sure that the water sensor on the machine (little black box that presses against the water tank near the bottom) is not wet and the tank is dry on the outside. I had mine get stuck because of that.
Posted on Jun 11, 2016
Why, when descaling a saeco talea giro plus only steam comes out of the wand
Try holding the descaling button for 6-7 seconds (not 3 as the instructions say) until it stops flashing.
Jun 11, 2014 | Saeco Coffee Makers & Espresso Machines
How to descale machine talea giro plus
Many times if you perform once more descale the problem can be solved so here is a video that can help to repeat the descale
Aug 28, 2012 | Saeco Odea Giro Plus Coffee Maker
Our saeco talea giro descaling light is on and after a full descaling cycle it remains in the descaling mode. any ideas? thanks
To remove a descaling light you need to hold down the steam/water button for 6 seconds and the light should go off. The button is located on the right side of the coffee button.
If you are in need of the manual you can download it here
May 10, 2011 | Saeco Talea Giro Espresso Machine
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
Talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
I have completed several descaling cycles on my talea machine, but the light will not go off. Help?
Check the manual there is a button that disables the warning after the descale has been done, on the Odea it is holding the hot water button for six seconds.
Oct 27, 2009 | Saeco Talea Giro Espresso Machine
Saeco Talea Giro Espresso Machine Logo
3,649 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
