Question about Troy Garden
I just emailed on previous page we have a two year old troybilt lawnmover that has always started perfect. Had not used for 5 months and would not start. Replaced spark plug, drained old gas and put in new gas and lubricated all springs. Will start for a second but then dies if I spray in starting fluid. Please help - we have irrigation in a couple hours and need to cut the grass before. Thanks, Melinda
    Novelist:
  • 111 Answers
There may be some water inside of the carburetor, or the carburetor needs to be cleaned. There could be water in the carburetor. To check to see if you have water in the carburetor you need to loosen the nut on the bottom of the carburetor (it helps to pinch off the fuel line to keep fuel from coming through the carburetor while you do this) and take off the fuel bowl and see what is in the carburetor. Most of the contents of the fuel bowl will drain out but there should be enough left to see if there is water or dirt mixed in with the fuel. When you take off the carburetor fuel bowl check to see if there is any corrosion on the carburetor. This may have a white, chalky appearance or if it is varnish from old fuel it will look like the carburetor has a "gold" appearance. The correct color of the carburetor is a dull or flat grey. If you find water in the carburetor bowl then there is a good chance that there is also some water in the fuel tank. You will need to drain the contents of the fuel tank. If you want to see what the fuel looks like you can drain it into a paint mixing cup or a clear jar. Start with a clean jar or cup, to make sure that you are seeing what is in the fuel and not what was left in the cup. lol. When you have drained the fuel tank and made sure there is no water in it, I would suggest putting fresh fuel back in the unit. See if the unit will start and run ok. If the unit pops or sputters while the engine is running there may be some more water that will come out after the unit is run for a little while. If the unit continues to not run or is not running very well you may have to clean the carburetor. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal.
Posted on Apr 03, 2011
I changed the password on Facebook about 6 weeks ago and forget what I changed it to the only way they are saying I can get it is the old cell number I used when I started my Facebook a couple years ago or...
Try recovering the password to your old email account. There should be a "Need help?" or "Can't access your account?" or some similar link on the sign-in page.
Sep 23, 2014 | Computers & Internet
Troybilt push mower will not start
Might be bad gas. Empty tank refill with fresh gas with Stabile. Might have to remove carb bowl clean and reinstall. Flush out tank with a little gas before refilling, disconnect fuel line to flush.
Aug 24, 2012 | Troy Garden
I wanmt my old mail, back
On your inbox go to the end of the page and you will see arrows which are for : moving to the next page, previous page and last page, go to the arrow that shows next and until you reach the last page you will be able to get all your mail back regardless you have been using yahoo continuosly without breaking for more than 6 months to a year. If you still cannot get your mail it means your account was suspended for over some period.
Feb 15, 2012 | Yahoo Mail
I need a owners manuel for a troybilt lawn mower
For Troy-Built USA, use this link and submit your model number and serial number to find and download your manual:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
For Troy-Built Canada, use this link and submit your model and serial number to find and download your manual:
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
All other countries use this page and find the applicable website or email address then go to the applicable website or email the contact point:
http://www.troybilt.ca/troybilt/contact-world.asp
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a 10 year old Mastercraft Canadian Tire 4.0 HP rear bagging lawnmover - always started great and ran great but now after it starts it keeps choking out. I changed the spark plug and the same...
You may just have some bad gas. try draining the system and putting fresh in. I usually drain some of mine into a glass jar and let it set for awhile. that way you can tell if there is any water in the gas.
Aug 20, 2010 | Garden
Hi my name is John Young and , I have a website software called Perfect Website Creator , it's about 5 years old and I'm looking to upgrade so that I can paste video on my front page . Do you'll have...
We don't sell produsts. Cosmi in an old and outdated product. Your best bet, would be to Google "Website Design Program". This will give you more possibilities than we can, and you can narrow it down to what you want and need.
Aug 12, 2009 | Cosmi Perfect Website Creator (ROM03919)...
Troybilt 6.5 briggs won't start floods gas
if it sat more than 3 months with out being started it needs a carb clean this can be done in an hour if your at all mechanically incline
1. remove carb and take it apart
2. buy a can of carb cleaner
3. spray carb cleaner in every hole ypu can find
4. becareful around rubber with carb cleaner it will swell it up
5. put carb together and reinstall
if the inside of carb is real bad get a rebuild kit and replace the parts
Apr 13, 2009 | Garden
Classic email page is all screwed up.
My first thought would be that your computor picked up a virus. I would do a full manual scan right away. Then take it from there.
Mar 10, 2009 | Yahoo Mail
Garden Logo
197 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
