Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
I have the bissell littlegreen proheat pet, and every time we turn it on to use it smells REALLY bad.. we always clean out the dirty tank and clean what we can get to but it STILL smells! i need to know how we can get the smell to STOP! i need some help on how to clean the rest.
Don't have a solution to the whole odor problem. But my machine smells musty or moldy so I have taken the dirty solution tank and turned it upside down and shook it filled with detergent. You can see the white pipe, or that's what I call it open so additional water drains out. But a bigger problem with my machine occured about 3 weeks ago. I was using my machine and when I picked it up off the carpet there was a black liquid that had come from the bottom of the machine. Which is not good given I have white carpet. I contacted the Bissell Company and they had me send the machine to them and they provided a prepaid shipping label. Also the company send me a bottle of pet and stain remover to get the stain out. As of yet the stain has not been totally removed. A bit of advice so this doesn't happen to you is to put a towel under the machine when using. I say this because I'm not sure if it is connected to the bad smell and thinking it might be a black moldy liquid. Hope this helps.
Posted on Apr 05, 2011
My bissell proheat pet works fine except it indicates that the dirty water reservoir is full when it actually is not and there is still clean water in the bladder part. It's a 2 in 1 tank.
There is a fluid level sensor that is defective or if it is a float it is sticking for the waste water tank, I would just ignore the light.
Nov 02, 2016 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Cleaning the tubes on the heater of a bissell proheat pet
just simply take a half a bottle of bleach poor it in the clean water tank use the hose and sprayer on a clean hard surface it will spray the clean bleach and suck up clean bleach and the bleach will do the job for you
Mar 18, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Bissell proheat 2x pet won't spray water or **** dirty water up
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Feb 13, 2011 | Bissell ProHeat 2X CleanShot Bagged...
My brand new bissel little green proheat pet series is spraying solution however it's not hot when it comes out. I put hot water in the tank & turned the heater on. Isn't this the whole point?
Have you checked the user manual? Can be found at http://www.bissell.com/searchresults.aspx?searchtext=little green&mode=userguides
If there is no element then the water will cool down naturally.
May 21, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Bissell carpet steamer not working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
Aug 08, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
How do you operate the Bissell 1725 LittleGreen Machine Proheat
Go to www.bissell.com then click the Customer Service tab. In the next window click on the User Guides link (in green on left hand side), then enter your model number. You can then download the full instructions.
Mar 15, 2009 | Bissell 1725-1 Little Green ProHeat...
Bissell ProHeat 7901 will not **** up water
heatman101
adfa
Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
344 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
