Question about Uniden DWX207 1.9 GHz 1-Line Cordless Expansion Handset
I need to know how to register this phone to its base didnt think that it was registered to its base and deregistered it and now went through all the steps to register it again and it wont...need help please...mine is a 6.0 not a 1.9
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
  • 8 Answers
SOURCE: Deregistering a phone you can't find
I had trouble deregistering one of the phones, as it has to be close to the original base (kept telling me out of range). I found out that pressing END and #, also deregisters.
Posted on Aug 25, 2007
SOURCE: Uniden TRU8885 Register/Deregister Issue
Here's what you do:
  • pull the battery
  • hold down * and # while reinserting battery
  • wait for beep
  • hit rightmost soft button (keys at top under the lcd screen)
  • wait for 'erase complete' message
  • hit end
Should work like a charm.
Posted on Dec 24, 2007
SOURCE: how to deregister a handset without the base with which it orginally registered
I successfully reset uniden TCX800 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near LCD.
Posted on Feb 24, 2008
SOURCE: nEED TO DEREGISTER LOST HANDSET
I had this problem too. Hold "End" and "#"at the same time fora few seconds and it will deregister. Then just put it on the new base.
Posted on Aug 19, 2009
Deregister cs-6629 handset
If your handset will not deregister, before registering it on a base. Here are the steps;
Menu/Select *7890#
It will display "Test Base" arrow up to "Test Handset"
Press Menu/Select It will display "SW Version"
Arrow up to "next page"
Menu/Select to display "Regstr Clear"
Menu/Select to display "Reg Clear?"
Menu/Select you should hear a beep.
Unplug battery and wait 10 seconds. Lug in battery and place phone in base to register it.
No other handset can be in use when you register new handsets.
Worked great for my 3 handsets that were registered to a base that went bad.
Nov 26, 2012 | Vtech DS6151 Cordless Phone
We replaced the base unit and can not register our existing handsets because they were registered to the previous base unit. Once registered the handset's menu doesn't offer a register or...
To un-register the SB67108 handset from a base unit, SB67118 or SB67138, you will need to do these steps in order:
1. Press menu
2. Key in this sequence *883247#
3. Select deregister
4. Unplug the battery for minimum 10 seconds
5. Plug battery back in and it will want to be registered.
6. Follow the directions in your base unit manual to reregister it.
That's it in a nut shell.
Jun 08, 2011 | AT&T SB67108 Phone
I need to deregister a DS6101 without the base. I needed to replace the base and once we installed the new base, the extra handset that we had registered with our old base shows the following message...
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Feb 16, 2011 | Vtech DS6101 19 GHz Cordless Phone
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
I need to deregister missing handset #1
To de-register HANDSET #1:
1) Grab any working handset which is registered to your base (so HANDSET #2 or #3 in your case)
2) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
3) Choose the "Deregister HS" menu option
4) Pick HANDSET #1 as the handset ot de-register (since that's the "phantom" registered handset)
5) Once de-registered, you can de-register handsets #2 and #3 directly from each handset's "normal" menu interface (i.e. press "Menu", choose "Deregistration")
6) Thereafter, if you re-register your handset, they should start at HANDSET #1, then #2, and so on.
Aug 27, 2009 | Uniden TRU8866 Cordless Phone
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Jul 11, 2009 | Lands Phones
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Jul 16, 2008 | Uniden TRU8885-2 Cordless Phone
Registering
place on base the will register your handset but make sure battery is charged now to deregister hold # end call button together for 8 seconds follow instructions for deregistering then once done place on handset to register
May 31, 2008 | Uniden Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Uniden DWX207 1.9 GHz 1-Line Cordless Expansion Handset Logo
43 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
